Speedmaster ls1 cast stroker crank.
Rods will be here next Thursday and pistons soon after. I'll keep posting how the build is going.
About 15 years ago an LS stroker rotating assembly from Lunati was about $4000. Some Australia companies explored the idea of doing cast LS1 stroker cranks. Some actually came to market and were successful in the Australian market. Other options became available in the US market for stroker cranks.
Some of us think the idea of an inexpensive cast LS stroker crank is viable in the US market. Scat has definitely sold a lot of cast small block Chevy cranks over the years.
While cast cranks aren't for true high performance use, they can make for a decent street motor.
https://ls1tech.com/forums/generatio...australia.html
Harrop in Australia lists an LS1 cast stroker crank for sale.http://https://www.harrop.com.au/sho...-stroker-crank
My RS & TA both have Callies cranks for their LS1 383 & LSA 416 engines but I'm keeping an open mind to the cast stroker crank. It would be perfect for 400 LS for a weekend cruiser that is a fun car but not really a high performance build.
My point is the OP has been verbally doubtful that this crank is even worth a squirt of llama **** almost expecting it to blow gorilla dick and "yet" it seems to check out just fine Will it hold 2000 horsepower of forced induction???HELL NO
But it seems likely to survive under the umbrella of his build parameters
. I ordered the 6.125 pro comp rods yesterday, still need to order the dss pistons I want.But tonight I bit the bullet and bought this junk
Its the 383 is coming along slowly but surely.
Exactly...this will be an excellent option for when I rebuild the 6.0L that powers my 86 dually tow rig.
Ed, I apologize. I didn't mean to muck up your thread, just really want to see this turn out for us guys that can't "break the bank"...
alper studs $130
alper spring kit $162
cast crank $190
procomp rods $276
dss pistons $430
241's with rockers $100
ls9 cam $116
balancing will be $200
honing bout $240
ls1 short block $200(came will full rotating assembly so you could say just the block was $100)
A 383 priced at $1828 for everything pretty much if you are building from scratch. Just add the price of whatever gasket set and bearings you choose.Oh and speedmaster does call for the thinner and radiused bearings most other stroker crank makers suggest.
alper studs $130
cast crank $190
procomp rods $276
dss pistons $430
ls9 cam $116
honing bout $240
Have you considered having the crank checked for cracks or other material defects? Having a crank inspected (MPI and/or X-ray) isn't too expensive and might save you from wrecking the rest of that shortblock if they do find something.
