Stock block ls1 with ASA cam and 61cc heads...bad idea?
Just picked up a 83k ls1 engine that I'm installing in a hotrod. I'm going to run it with a carburetor. I'm looking at a dual plane, ASA cam (226-236 .525.525 110) or the new higher lift .600 same specs. I found some 799 heads ported and milled to 61cc I was thinking about. Would this be a bad idea? I'm new to the LS world but have built lots of older gen 1 sbc engines. I'm excited and want to do this right the first time. Thanks
Moderator
Received 1,835 Likes
No, this would be a pretty good combo for good midrange torque
I'm on the hunt for a 6spd and the rear end is a 12 bolt 3:73 posi. This is going into a 70 Camaro. should I be concerned about this engine having 83k ish miles on it or should I be ok with sticking a cam, heads, ls7 lifters, pushrods, timing chain and let her rip?
Maybe put a new oil pump in it just for peace of mind....
LS1Tech Premium Sponsor
Our high lift ASA cam will fit with .030 milled 243s. Aboit 60cc. The gm one wont. Ours has 1* less advance just for ptv issues like you would run in to. Make SURE you measure pushrods and do not use a thinner gasket.
Itll be great for mid range and top end on that intake setup.
