Sac City Corvette oil bypass plug install in pics
I wanted to do a vid ....but had to settle for pics
what you need
bypass plug ( very important )
1/2 inch allen wrench
Vaseline
10mm socket and rachet ( or wrench )
new gasket for outer cover
what you need
Vaseline
look down the hole where the cover was and you can see the other end of the factory bypass plug
at the bottom there is just a hair of room to get a small screwdriver under it.....use the screwdriver to pry the plug up n out
Thank you for your business and for the great write up! Very helpful!
Christian
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Thanks for the compliment on our products!
I'm not quite sure what you mean when you say "Since the oil filter can no longer be bypassed with this plug". Can you explain more?
Thank you,
Christian
__________________
Hope I'm not misunderstanding this whole thing! Isn't the idea of this plug to eliminate the oem oil bypass? That's what I meant by "Since the oil filter can no longer be bypassed with this plug".
The oem oil bypass opens when there is too much pressure across the filter medium (like cold startup when the oil is thick, or when the filter becomes too dirty). So although sending unfiltered/dirty oil through the engine is bad, I'm guessing too much pressure in the filter could be worse as they can only contain so many psi before they fail.
So I was just wondering if you delete your bypass valve (with the plug), can you still use the same oil filter you always did? And should it be changed more often?
Maybe I'm overthinking this. If so, please let me know. I'll just order one instead
Hi computerz,
I think I see what you mean now. Pretty much all the good quality filters have a bypass built into them should it get plugged up for some reason. Generally anyone installing one of our Bypass deletes or Billet Barbells is doing so because they don't want unfiltered oil going through their engine bearings & lifters. Those people keep their oil and filter clean and don't need to worry about the filter getting plugged. When the oil is cold it will still flow through the filter and again, the guys running these products aren't revving and being hard on their cold engines. We recommend running a good quality filter with or without these upgrades.
Hope that helps clear things up. :cheer:
Thanks
Christian
Thanks
Christian
__________________
