Balancer install, use lube inside the hub or no ?
Old Jan 5, 2018 | 01:07 AM
sjsingle1's Avatar
Default Balancer install, use lube inside the hub or no ?
I would not think to put it on dry, but use some kinda lube inside the hub bore to cut down on friction ??? yes or no ?
Old Jan 5, 2018 | 03:19 AM
Karlw's Avatar
Dry! It's not keyed so the only thing keeping it from spinning is the interference fit.
Old Jan 5, 2018 | 06:59 AM
vettenuts's Avatar
Are you installing stock or aftermarket?
Old Jan 5, 2018 | 01:51 PM
sjsingle1's Avatar
aftermarket....no keyway
Old Jan 5, 2018 | 02:13 PM
01ssreda4's Avatar
Hell yeah put some oil on it. It wont spin.
Old Jan 5, 2018 | 04:09 PM
I’ve lubed everyone I’ve ever installed, Oem and keyed aftermarket. No issues ever.
Old Jan 5, 2018 | 07:54 PM
01ssreda4's Avatar
The pressure of the bolt head AND the interference fit keep it from spinning. It ain't going anywhere.
Old Jan 5, 2018 | 08:09 PM
Right. The interference fit pretty much squeezes/scrapes the oil away. The fit pretty much is metal to metal.
Old Jan 5, 2018 | 09:51 PM
sjsingle1's Avatar
ok....oil it is !!! any preference on type ????
Old Jan 6, 2018 | 07:23 AM
epfatboy's Avatar
Slippery
Old Jan 6, 2018 | 08:05 AM
85LSXTRUCK's Avatar
I always WD40 mine. Those suckers can be a bitch to get on some times. Mine never slipped.
Old Jan 6, 2018 | 09:42 AM
LLLosingit's Avatar
You can also warm the balancer up in the oven a little bit to help them go on easier.
Old Jan 6, 2018 | 01:15 PM
epfatboy's Avatar
I just heat the snout of the balancer with a torch until the you feel the heat coming into the 3 " "supports".
Should slide on but if not be ready with the old bolt and a impact to drive it on the rest of the way. The faster you do it the better off you'll be, it cools very quickly.
Note there will be a gap between the outside of the balancer and the end of the crank, it's normal.
Old Jan 6, 2018 | 01:29 PM
93Z2871805's Avatar
Veteran: Air Force
It'll be .094-.176" for a stock damper, .200-.285" with an ATI.
Old Jan 7, 2018 | 01:44 AM
sjsingle1's Avatar
ok...got it on
put it in the oven 200
cooled down before i could really get it on
the GM tool proved to be on the short side .....luckily had another tool handy
did use wd40....not very slippery
every turn of the nut made the balancer go POP....scared me !
if i was to do it again i would use assembly lube !
Old Jan 7, 2018 | 07:55 AM
epfatboy's Avatar
Congrats.... what bolt are you using?
Old Jan 7, 2018 | 08:45 AM
qweedqwag's Avatar
Originally Posted by sjsingle1
ok...got it on
What I used.
Old Jan 7, 2018 | 06:29 PM
sjsingle1's Avatar
ARP bolt
