LQ4 with LM7 cylinder heads
Old 01-05-2018, 10:36 AM
Venomous281's Avatar
Default LQ4 with LM7 cylinder heads
Hey guys, ive googled and searched but only came out with old threads and unanswered questions. I have a 2000 LQ4 with iron heads in my Sierra. Im wanting more compression as i run dirt drags and run E85 in my truck so octane wont be a problem with the rise in compression. A little about my setup; 2004 Sierra RCSB 4x4, lq4/4l80e, TBSS intake manifold, 87mm tb, 214/224 on a 115LSA, .625 springs, pushrods, stock manis, with y pipe and no cats, exhaust is a 4" magnaflow with the y pipe cut at the merge for a uncorked exhaust, 36lb injectors, Walbro 450 e85 pump, my truck runs really good right now but i want more power and i have some LM7 heads laying around. My questions are, has anyone ever done this and did they feel a difference? Will it feel the same if i dont install a bigger intake valve? Ive heard it feel slower since the valve is smaller. But i honestly think the bump in compression will help more.
rear fender flares are being painted.
Old 01-05-2018, 10:57 AM
Received 3,179 Likes on 2,484 Posts
Find some 799's, which are identical to 243's. They are on most 5.3 trucks since 2007
Old 01-05-2018, 11:03 AM
i know they are, but im asking about 706/862's. The main reason i want LM7's is so when i pop the hood they see 706/862 and they continue thinking its stock. If i put a set of 799/243's ill get bumped to the modified class. My buddies run the modified class and are way faster than me.
Old 01-05-2018, 11:10 AM
01ssreda4's Avatar
Yes they will make more power due to the compression increase if thats what youre asking.
Old 01-05-2018, 11:41 AM
Basically what i was asking if i will feel a loss in power if i dont install 2" valves. sorry if i made it hard to understand
Old 01-05-2018, 11:54 AM
omc8's Avatar
What are the rules for this class ? You can run oversized valves , you can port them I take it . Yes you having a 4" bore you would benefit from the 2" but you need to do chamber work .
Old 01-05-2018, 12:14 PM
A.R. Shale Targa's Avatar
The compression increase, specially if you mill them .030" (and I would) will more than offset the minor flow lacking from the 1.89" intake valve. Personally I would have a local shop do a valve job for the 2" valve and some minor bowl blending, but if you're on the "cheap"; mill, lap the current valves, and install
That cam will LOVE the compression hike
Old 01-05-2018, 01:20 PM
Class rules for stock class are; no headers, exhaust ok, cold air intake, tune. All other mods will throw you in modified. But my cam isnt noticeable, and the intake manifold hides under the stock intkae cover.
Old 01-05-2018, 01:21 PM
I really want to do a set of 2" valves and have them milled but the guy that does my head work is booked for a while. So I'm thinking they're going to go on with the small valved and unmilled.
Old 01-05-2018, 01:41 PM
Well the LS2 head gaskets are quite cheap but at .051" they are thicker than needed
You can cheat a tad by running .040" Cometic gaskets which are more expensive but about the same as paying a local shop to mill.
Old 01-05-2018, 01:43 PM
I think i have one ls2 gasket in my toolbox. i need to check what i have. Some cometic .040's would be nice though. But i think ill do cometics when i get a nicer set of heads.
Old 01-05-2018, 01:45 PM
Compression will be 11.36:1 with the factory LS2 gaskets and the 61.5cc heads
Otherwise 11.70:1 is possible with the Cometics
Both of these will work great and love the E85 plus since manifold vacuum will increase, that cam will sound even smoother
Old 01-05-2018, 01:48 PM
Also wonder if LS7 manifolds would fit or even C5 Tri-Ys from 01-04 are better flowing than the log stuff....those are meant to be mounted backwards and running into one of those spinning muffler thingys....
Old 01-05-2018, 01:49 PM
01ssreda4's Avatar
They will flow fine with the smaller valves in my opinion.
Old 01-08-2018, 07:19 AM
I was going to turbo it, but i'm looking for another truck that isn't so nice to turbo again. Thanks for your input, i appreciate it.
Old 01-08-2018, 07:20 AM
Awesome, thanks.
Old 01-08-2018, 09:18 AM
cookseyb's Avatar
Send the 706-862 heads to Texas Speed for their upgrade, Beautiful work!!
Old 02-05-2018, 03:05 AM
Big bird55's Avatar
Correct me if I'm wrong but an lq4 with 59 cc heads and .051 gaskets should be around 10.7 :1. Where is that 11 side coming From?
Old 02-05-2018, 07:54 AM
I finally got around to swapping the heads. I still havent gotten it retuned but i plan on it this week. But i just got some livernois motorsports stage 3 243's and a 235/244 cam ill be swapping in once i get a stall converter next month.
Old 02-05-2018, 08:26 AM
stockA4's Avatar
That's a gigantic cam for a big truck! I hope you are ready to be disappointed with the losses your going to see on the low end.
I was really interested to hear how the stock 4.8/5.3 heads would work on the 6.0 let us know before you go and ruin it with that donkey dick!
Quick Reply: LQ4 with LM7 cylinder heads
