Same cam, new heads, pushrod length question
Old Apr 9, 2018 | 09:25 AM
Gripenfelter's Avatar
Default Same cam, new heads, pushrod length question
Local shop says to use the same pushrods. I checked the length with the comp cams pushrod checker. 7.400 is where there is no play and the bolt is finger tight (11 turns on the pushrod checker). My old pushrods were 7.400. Using Johnson lifters and Yella Terra rockers btw. Johnson lifter preload is 0.035.
So the question is:
Should I get 7.435 pushrods or should I stick with the 7.400 pushrods because it won't make much difference?
Local shop said no. My old pushrods were 7.400 on this cam. But I have TFS heads and Yella Terra rockers now. I was surprised they were still the same length. But my car buddies here say I should get longer rods.
Old Apr 9, 2018 | 02:28 PM
vettenuts's Avatar
Based on your post, if you use the 7.400" you will be at zero lash. Not sure why the local shop is recommending their use.
Old Apr 9, 2018 | 04:15 PM
They told me to run it and see what happens because the lifters will "pump up".
Old Apr 11, 2018 | 01:21 PM
nine8ss's Avatar
Subscribing to find the outcome of: "run it and see what happens".
Old Apr 11, 2018 | 01:24 PM
LOL.
I'll report back in a couple of weeks.
Old Apr 12, 2018 | 01:03 PM
Broken944's Avatar
Sounds like they would be too short in my opinion. I don't know about them pumping up making the difference. Are the lifters that soft that they would depress with things just finger tight?
Old Apr 12, 2018 | 01:33 PM
garygnu's Avatar
how much is the block decked ,heads milled ,how thick is the head gasket ? got 7.500 push rods with my TFS heads .
Old Apr 12, 2018 | 09:37 PM
brobinson216's Avatar
My TF 220's required 7.400" with the 2110's.
Old Apr 13, 2018 | 09:00 AM
Block isn't decked. Heads were milled to be 61 cc (not sure how many thousandths). 0.051 head gasket.
I'm gonna re-measure mine in 1/4 turns. I did 1/2 turns before. Also I'm going to colour the tips of my valves with a black marker and look for wear marks after I turn the motor over a few times with 7.400 pushrods installed. That will tell me where the rocker sits on the valve and if it's too short.
Old Apr 13, 2018 | 10:16 AM
I don't use the turn method as it's not relevant. Run the rocker bolt down while spinning the pushrod with your fingertips. Once the pushrod begins to tighten in rotation, that is zero lash.
Add your preload and that's the size pushrod to use.
You don't mention which lifter part number, rather .035" of preload. If the lifter is indeed the 2110 then set the preload at .050" which will be fine. I'm thinking they have .150" of plunger travel.
Another thing I didn't mention is the fact I'm using Harland Sharp rockers. The TFS heads need a quality roller rocker to reduce guide wear as introduced by the factory rockers.
Old Apr 13, 2018 | 10:19 AM
If I use your method of spinning the pushrod I would probably get different results. I'll try tomorrow and post my results using your way and the marker tip way.
I'm using Yella Terra roller rockers to reduce guide wear.
The lifters are Johnson 2116LSR (slow leak down).
Old Apr 13, 2018 | 10:58 AM
Given the fact you have procured nice expensive parts. Take the time measure each and every I/e and call Manton with the requirements.
As others have stated if zero lash is at 7.4 then you don't have enough preload to suffice the plunger. If ordering Mantons is not a viable option I would order a set of 7.450", most generics will be .005" shorter than advertised.
My statement on the rockers was more of a blanket for future reference. I killed a set of valve tips with stock rockers in 2007.
Old Apr 13, 2018 | 11:02 AM
Yeah I was warned by Mast Motorsports about the TFS heads and guides.
Old Apr 15, 2018 | 12:36 AM
I feel really dumb making this post. The pushrod was caught up on the lip of the lifter so it gave an inaccurate measurement. Actual length of pushrod came out to be 7.650” with lifter preload.
I borrowed a 7.650” from a buddy and installed it at 22 ft-lbs. Coloured the tips of the valves with a marker to see where they would wear. The wear line is pretty much in the middle. If it was closer to the center of the motor it would mean the pushrod was too short. If the wear line was closer to the fenders it would mean the pushrod was too long.
http://i329.photobucket.com/albums/l...sengl2li3.jpeg
Old Apr 15, 2018 | 01:02 AM
Don't feel dumb, it's happened to me before as well. Post back after you question yourself tomorrow and remeasure.
Old Apr 16, 2018 | 01:58 PM
vettenuts's Avatar
Pushrod length will not change the wipe pattern of a fixed fulcrum rocker like the stock LSx or the Yella Terra. Only way to affect the wipe is with shims or material removal depending on where the wipe pattern resides and its width.
Personally, that pattern should be redone to get a better wipe so you can gauge both position and width. You shouldn't do this by turning over the motor as the hydraulic lifter will skew the results. Once you have an accurate wipe pattern determine if the rocker height needs adjustment to obtain the correct wipe, then measure and purchase pushrods with the correct rocker height.
