losing crank sync bent reluctor?
Old Jun 6, 2018 | 01:59 PM
freaky57fast's Avatar
Default losing crank sync bent reluctor?
Hey all, just got my engine in my car a month or so back. First start up was good then it seemed once we got ready to tune the car wot was freaky acting. the car lost sync and would create what seems like a rev limiter at 2k.. Switched the crank sensor and fixed that. Then started to do wot tuning and the car has a fake rev limiter at 6500 rpms now will not get worse like it originally did, but wont get better and sometimes will carry into second gear even and act up at 4k... Dove into more of the car found the 24x wheel was a bit separated. would a separation on the wheel make this issue? I would assume it should act funky all over the place or not even start... We are going to pull the crank and get a billet wheel installed now hoping this is the issue.
car is a fox with a ls1 stroked and bored darton sleeved, ms3 evo computer and a powerglide. so you can see why the rpms are needed. if it was a turbo400 and didnt carry over the problem after a shift i wouldn't be as pressed to fix it but i cant even make a quarter mile pass and i still shift before the eightht so i cant even do short track fun... anyone use ms3 and have a similar problem or have a bent wheel and have similar problems?
Old Jun 6, 2018 | 02:57 PM
ddnspider's Avatar
I believe the tolerance on the reluctor runout is .020" with aftermarket being .030" or better. Did you measure the runout?
Old Jun 6, 2018 | 04:36 PM
We did not measure it was in the car and we just used a scope to look at it will turning the engine by hand. It is noticeable by the naked eye. I just figured if it was causing issues at 6000+ rpms it would cause problems ever place else. I forgot to mention i was using a parts store sensor at first then swapped to a factory sensor to get the results i am currently having.. I'm sure it has something to do with the issue but was just puzzled why the car works everywhere else in the rpm band..
Old Jun 6, 2018 | 08:14 PM
kossuth's Avatar
Its tighter than that. Reluctor Ring RO: 0.25mm / 0.01" (Measured @ 1.0mm/0.04" below tooth Dia.)
OP if it’s super noticeable by the eye then you have more run out than spec. Could that be the source of your issue? Maybe or maybe not, but I would bet that is the primary source of it.
Old Jun 7, 2018 | 02:32 AM
Was leaning towards it being the problem as I said I'm doing a billet wheel tomorrow. Just makes me wonder why it isn't affecting anywhere else the car performs besides when it shifts out of it into second gear it occasionally does act up. I figured it would be funny at lower rpms but it drives perfectly normal below 6k even when babbying into the trouble spot it acts up. I'm the kind of guy where it'll get fixed but I'll still wonder what the heck. Bwe back with updates by Saturday.
Old Jun 7, 2018 | 07:20 AM
ddnspider's Avatar
That may be the GM spec, but there's plenty of info available from others who've measured aftermarket cranks that are typically ~.02" and had no issues.
Old Jun 7, 2018 | 04:37 PM
looks like wellwfind out sooner if that's the issue..
Old Jun 7, 2018 | 07:09 PM
kossuth's Avatar
Ok, just for perspective .02 is about 1/3 the thickness of a penny. When you put it in that perspective the ability to see any runout with your naked eye means something is way way off.
Old Jun 7, 2018 | 07:34 PM
There ya go..... IF you can see it, it ain't good! Gotta change it......
Old Jun 7, 2018 | 07:41 PM
ddnspider's Avatar
Im not doubting that if he can see it it's way out. I'm simply saying what I acceptable from a sensor and PCM perspective. I've seen them 60 thou out and knocked back to within 10 by hand using a dial indicator.
Old Jun 9, 2018 | 09:45 AM
The reason for the post wasn't asking if the run out was the problem it was why is it only an intermittent problem and not affecting the car besides at 6k rpm not even wot pulls it will even happen when i half throttle past 6k...
Old Jun 9, 2018 | 11:16 AM
kossuth's Avatar
Well, let’s look at what you’ve figured out. The behavior changes for the better upon the replacement of the crank sensor with an OEM unit, but you still have a weird issue.
I suspect crank signaling is still your problem. Whether it be from the reluctor(which I suspect is out of tolerance) or the signal is breaking up from interference from something else electronic in the car.
Do you have an electronic scope like a PICO or similar? Also is this a you made harness or a vendor make harness for your swap? Because when you get the reluctor run out deal straightened out and on the chance still does it then you need to scope the various sensors on the motor to find out if your signal is breaking up.
Old Jun 9, 2018 | 12:05 PM
Sounds like past 6000RPM it has a harder time reading it due to the slight reluctor alignment issue. I still think if you fix the reluctor it will go away.
Old Jun 9, 2018 | 02:41 PM
Originally Posted by G Atsma
Sounds like past 6000RPM it has a harder time reading it due to the slight reluctor alignment issue. I still think if fix the reluctor it will go away.
And that was my thoughts as well, the difference in rotations a second even are drastic compared to 5500rpms.
Old Jun 9, 2018 | 02:49 PM
Megasquirt3 evo ls24x harness. I had it on the car when it had a 6.0 would run to 7200 like i wanted it to. I wanted to assume the harness was stretched but didnt find anything out of order in the harness. next step will be re pinning the ckp wires. it is straight up lost of crank synce the computer tells me so. I was just wonderikng if anyone would have an answer for why it only happens above 6k. i know its crank sync just curious why the car runs perfectly fine besides the top end. Maybe even start the thread incase someone else runs into trouble down the road, only ones i found on the subject the op noticed the reluctor was fubar before they assembled the engine, or even wouldn't start. I was on the fence about the wheel being the problem and not just the computer until i looked at it while rolling over the crank by hand. my next post will be after i install the billet wheel which i suggest anyone with a 24x buys and has installed if thier engine is apart, its a very nice piece compared to the oem wheels.
Old Jun 20, 2018 | 04:55 PM
Update: Wheel was separated worse than i though once i took the crank out. Replaced with a billet callies wheel and new crank that hasn't been cut just for piece of mind. For future builds we're always using a one piece wheel on the 24x reluctor cars. Unless the problem continues which i doubt after we start up and tune, this thread has closure for anyone else that has the same issue in the future.
Old Jun 20, 2018 | 05:24 PM
ddnspider's Avatar
What do you mean separated? Like the 2 pieces that set the count were split? Got pics?
Old Jun 21, 2018 | 12:00 PM
Yes the two sets were apart i have them on the old crank still can get pictures tonight if i remember. It didn't seem bad until it was next to a stock wheel that had no issue. Engine is back together just waiting to get help to lift it in.
Old Jun 21, 2018 | 01:11 PM
00pooterSS's Avatar
In for pics of the separation, I really wanna see this. I'm trying to picture it but not really working out.
ddnspider's Avatar
Id like to see pics and how far apart they were.
