No stamp on heads??
Old Jun 24, 2018 | 07:56 PM
Tcombs911's Avatar
Default No stamp on heads??
Just picked up a 1998 trans am. And there’s no stamp on the heads indicating what size they are? I’m guessing factory but I have no idea.
Last edited by Tcombs911; Jun 26, 2018 at 11:33 AM. Reason: Added another picture of the heads
Old Jun 25, 2018 | 10:39 AM
KCS's Avatar
KCS
Moderator
Thats weird. You might have some luck pulling a valve cover.
Old Jun 25, 2018 | 10:51 AM
fst100's Avatar
whats the history of the vehicle? was it from a dealership or private owner and if the latter, any idea on how many previous owners were there? did the car come with any mods done to it? from the 2nd to last and last pic, looks like the car has headers and not the stock manifolds.
Old Jun 25, 2018 | 11:44 AM
Tcombs911's Avatar
those pictures was took yesterday in my drive way lol. I bought it off of a private owner in tenneseee. I know it has headers, true dual exhaust-mufflers and turn downs, rebuilt auto transmission with a shift kit and a rear end out of a 97? As for the engine I have no idea. I saw the heads and was confused...
Old Jun 25, 2018 | 12:19 PM
cookseyb's Avatar
Probably changed, I think 1998 had perimeter bolted valve covers..
Old Jun 25, 2018 | 12:24 PM
fst100's Avatar
the heads also could had been removed and swapped with a different set of heads and put back on opposite sides. see if there's any numbers on the ones near the firewall. will prolly have better luck looking at the heads on the driver's side.
Old Jun 25, 2018 | 10:53 PM
RB04Av's Avatar
Heads are the same both sides.
Looks like somebody ground off the casting #. (Pass side front, driver's side rear)
Definitely newer than 98. Been swapped, no question.
Old Jun 26, 2018 | 12:07 AM
Tcombs911's Avatar
I got a picture of the numbers on the side of the head when ever they approve the picture on here lol
Old Jun 26, 2018 | 07:15 AM
Ls7colorado's Avatar
Looks like an Iron block from the picture? Maybe just dirty If so then its probably a 4.8/5.3 and someone scraped the numbers off the heads so it wouldn't be a dead giveaway
Or maybe there some ported heads and thats the way the person that ported them stamps his LS heads lol
Old Jun 26, 2018 | 07:24 AM
gagliano7's Avatar
Under the valve cover there should be #'s on the head.
Old Jun 26, 2018 | 09:27 AM
Texas Blue's Avatar
Very strange and that's definitely an iron block like someone mentioned earlier.
Old Jun 26, 2018 | 11:10 AM
Tcombs911's Avatar
I added a picture or some numbers for you guys. I’m lost. I sure hope someone didn’t put a 5.3 in it
Old Jun 26, 2018 | 11:20 AM
mk3cn4's Avatar
Does a magnet stick to the block? Might have a 6.0 in there.
Old Jun 26, 2018 | 11:23 AM
If it's an iron block, it's either a 4.8, 5.3, or 6.0. There should be an indicator on the end of the block.
Old Jun 26, 2018 | 11:32 AM
Tcombs911's Avatar
magnet does stick. And it has a stamp on it. Posted it back up top with the rest.
Old Jun 27, 2018 | 02:19 PM
HappySalesman's Avatar
THat stamp doesn't actually tell you anything. The casting number is located on the back of the block on teh drivers side, just behind the cylinder head. Just below that, inside where the bellhousing bolts up, it has a stamp indicating the displacement of the motor.
However, nothing will REALLY tell you anything unless you do some disassembly. Motor could be bored, stroked, etc. WHat did the previous owner say was in it?
Old Jun 27, 2018 | 03:40 PM
ss.slp.ls1's Avatar
Is it just me or is your temp sensor busted?
Old Jun 27, 2018 | 05:50 PM
RB04Av's Avatar
No I think you're right ... it does look kinda ... impaired. Challenged maybe even.
The block does look cast-iron. So, not a LS1. Might be a 4.8, 5.3, 6.0, or something; but not the original motor.
Old Jun 27, 2018 | 10:27 PM
Thats always the first thing I check before buying, could be a 6.0 but like I said earlier Im almost certain someone just scraped the numbers off of some 4.8/5.3 heads so no one would be able to tell what was in it. Ive seen it MANY times were people try to pass off a 5.3 swapped car as a LS1 but never seen someone scrap the numbers off the head to cover it up.
Old Jun 27, 2018 | 11:24 PM
Pretty hard to pass off a 5.3 iron block as an LS1 seeing as how there are NO 5.7 iron blocks from the factory. If it's iron, its either a 4.8, 5.3, or 6.0....
