Ls1, 61cc heads, .040head gaskets....to much for 91 octane?
Building a carbureted ls1 for an autocross weekend toy and want as much mid range power I can get. Car will have a 6spd and bolts on, cam, headers, pulley, ported heads ect. Will a factory short block with milled AFRs at 61cc with a .040head gasket (good quench) be to much compression for 91 fuel? In Idaho it's hard to get 93 these days. I have not picked a cam yet. Thanks guys
~61cc = chamber
~0 = piston head volume (no dome or valve reliefs)
~0.010" = deck clearance (piston out of the hole)
~3.910 = gasket bore
~0.040 = gasket thickness
~3.898 = engine bore
~3.622 = engine stroke
** = 11.589 SCR **
same numbers as above but with a piston 0.005 out of the hole.....
** = 11.438 SCR **
As others have said....DCR is what makes or breaks the octane requirements.
Will you possibly need to flycut ?
