Lq4 build
Old Aug 25, 2018 | 12:24 PM
70_velle's Avatar
Default Lq4 build
Hi all, I’m planning on building an lq4 for my 70 Chevelle. The motor is going to be NA at least for a good portion of its life and I want to make a good amount of horsepower (500+). Would I be better off stroking the motor or leaving it and just cleaning it up a little? Which route is cheaper and more durable? Any tips and advice would be much appreciated
Old Aug 25, 2018 | 12:58 PM
What kind of budget do you have? I feel that a stroker is a great way to go, as long as your not planning 8k rpm blasts.
Are you planning to go EFI, or carb?
500 hp at the crank is relatively easy with 6liter setup.
Where are you located?
Old Aug 25, 2018 | 01:05 PM
70_velle's Avatar
I haven’t really decided on a budget yet lol, I’m planning to go carb but I’m open to efi if it means I can meat my goals with les money put into the project. 500 at the crank is roughly what at the wheels? And I’m in Nova Scotia Canada
Old Aug 25, 2018 | 01:17 PM
You’ll save a little coin going carb, just on the fuel system, but man is efi nice to have for reliability and tuning. 500 crank is low 400’s with a manual trans, and depending on the particular automatic, 375-400.
Unless you’ve got an open checkbook, id figure up a budget before you start the process. I’ve seen many, many guys start an ambitious build, only to get in over there head financially, and end up giving the project away for pennies on the dollar.
Try to find a pullout engine with the harness intact, ECM, etc, and you’ll be money ahead. You can put the fuel system together for a few hundred more, depending on if you want pump in tank, or in-line.
Old Aug 25, 2018 | 01:19 PM
Check out the conversion section on here. There are metric tons of builds to study up on...
Old Aug 25, 2018 | 01:25 PM
70_velle's Avatar
I was hoping to get closer to 500 at the wheels, it’s an automatic likely a 4l80e and I guess if I had to decide I’d like to be in the 5000$ range. On a side note you have a beautiful build going on!
Old Aug 25, 2018 | 01:34 PM
70_velle's Avatar
I will say though that budget isn’t a huge priority as I have a running motor in the car that works well so I’m not in a big rush to build this motor, if it’s going to cost a lot to get what I want I’ll just buy the parts as the funds are available
Old Aug 25, 2018 | 02:40 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Youre really going to need a 408 for that and a good set of heads for 500rwhp.
I would recommend the tsp 237cc cathedral or 260cc ls3 heads, a nice 408 flat top setup and a good sized cam and youll be in the 500rwhp easily. it will take alot more effort to make 500 on a 6.0 but nearly the same amount of money really.
We have all those parts available
Old Aug 25, 2018 | 05:44 PM
70_velle's Avatar
can you give me a ball park price if I went 408 for everything
Old Aug 25, 2018 | 05:50 PM
408 balanced with bearings runs about $2720.
Heads and cam are roughly $2950.
So 6k roughly for a complete setup gaskets and all.
Old Aug 25, 2018 | 06:00 PM
70_velle's Avatar
awesome! Thanks
Old Aug 25, 2018 | 06:16 PM
Tuskyz28's Avatar
TFS 220s for the heads.... why play around ?
Old Aug 25, 2018 | 06:18 PM
Because 220cc is small for a 408 and the tsp 237s well outflow them.
The 225 tsp are close but edge em out also but still small for a 408.
Old Aug 25, 2018 | 07:08 PM
70_velle's Avatar
would the 260cc ls3 heads be just as good as the 237s? Just did a little looking and they seem cheaper
Old Aug 25, 2018 | 07:18 PM
They are the same price plus need new rockers and rails. They are also $150ish more than the 237s.
Old Aug 25, 2018 | 07:27 PM
70_velle's Avatar
above you said 408 balances with bearings is 2700 is that for a new block or an estimate on what the machine work would cost?
Old Aug 25, 2018 | 07:31 PM
Thats just 408 rotating assy balanced with bearings.
Old Aug 25, 2018 | 07:35 PM
But i meant $2550 sorry not 2700. Thats for pin upgrade.
Old Aug 25, 2018 | 07:40 PM
70_velle's Avatar
ok, thanks a lot for all the information!
Old Aug 25, 2018 | 07:46 PM
Tuskyz28's Avatar
Misread the thread. OP went from 6.0 to a stroker build. I say TFS 235s. They made my boy car run low 10s at 133 with slouchy 60ft. Also made 550 on a mustang dyno at the rear wheels on a 402 LS2 motor.
