Oil leaking from driver dust cover hole
I'm wondering if the hole is too far forward towards the front of the vehicle and if it has penetrated the inner wall of the oil pan
I confirmed the culprit.
Oil is coming out the hole because it is in fact drilled too far towards the front and did breakthrough the inner wall of the pan.
It's difficult to see here, but in the mirror you can see the hole inside the hole.
Moral of the story: Dorman oil pan is rubbish. Learn from my mistake and don't buy this garbage
That's a pretty terrible QA process that leads to a sub par product. While I'm able to work around this, it does not negate the fact that the end product is not good.
At this point if I can get it to "work" I'll be happy. The JB weld appears to be holding up, but I found a leak in the steering rack that required me to put the car back up shortly after running it.
You won't ever have to worry whether that will hold or not, unlike JB Weld. It's just NOT the "big deal" everybody seems to be making out of it.
