UPDATE POST 58, UPDATE POST 29 randomly got sewing machine
as far as the type of oil, just because it is rated at a "something-somethingW30" doesn't mean it will act like every other multigrade oil at temp. they are all a little different, some formulations have higher viscosity than others at temp but still all fall into a certain weight range. i would worry more about wear protection than a little valvetrain noise, though.
Honestly, nobody can tell you what it is without looking at it so you really should look at it.
what should i look for when i pull the covers?
I hear ya there and i'd love to give you that answer, but if I did or we did then we could be telling you to go beat on a hurt motor, so you're gonna have to look. I think that yeah if you triple checked your lengths and it was quiet that it's safe to assume the pushrod length isn't the problem.
So what I would look for is are any of the rocker arm bolts loose.. once they are off rotate them around and feel for any looseness or any rough spots or anything that looks or feels off, compare them to each other, any of them have looseness or funkiness compared to the others, if so check that one out, if not move on.
Pull all the pushrods, look for funky wear, roll them all on a flat surface and see if any are bent. If they look good and are flat move on.
Look with a flashlight down into the lifter cups see if they all look good.
Look at all valve springs make sure none of the coils are broken, make sure all of the tips of the valves are perfectly flat and smooth, no funky wear. Make sure all the retainers are in their place and all the keepers are all there.
If you don't find anything take a couple more pushrod measurements and see if something changed, if not put it back together and either run it or pull the pick up tube and check your oil pump o ring
