Rocker arm compressing spring.
Old 03-10-2019, 09:11 PM
chr45gt2's Avatar
Default Rocker arm compressing spring.
So I put piston 1 at TDC and follow the usual procedure to tighten certain intake and exhaust rockers, however the intake on number 4 never reaches 22lbft, it just keeps on going and compresses the valve spring, which gives me ptv contact when turning over the engine. All the other intakes and exhausts torqued up fine with no spring compression and when I back off #4's intake I can turn over the engine just fine. I did put some number 2 sealant on the bolt(ported heads). Maybe a bit too much. Could this be causing it to not reach the torque value?
Old 03-10-2019, 10:11 PM
s30.hybrid's Avatar
Not fully reaching final torque makes me think stripped rocker boss threads, but seems unlikely if it’s compressing the valve spring. First you need to make sure cyl 4 is a TDC, im guessing it’s not. Once you verify that, then try to torque at 22#. If it still won’t torque then the threads may have been damaged from trying to tighten the rocker while it was not on the cam base circle.
Old 03-11-2019, 09:25 AM
chr45gt2's Avatar
I don't think the threads are damaged, the bolt screws in and out easily. I'm gonna clean off all the gunk I put on there and try again.
Old 03-11-2019, 11:38 AM
Jgaines8679's Avatar
What's the engine and cam specs? Stock pushrods?
Old 03-11-2019, 12:11 PM
00pooterSS's Avatar
Sounds like the lifter is pumped up or something is out of whack like maybe the pushrod not being seated in the cup on the lifter.
It's holding your valve way too far open for some reason.
Old 03-11-2019, 05:11 PM
99 Black Bird T/A's Avatar
Received 1,435 Likes on 995 Posts
Does does everything check out OK with the push rod on #4 intake? Could it be shorter or longer than it's supposed to be?
Old 03-11-2019, 05:19 PM
00pooterSS's Avatar
Also you said you're following the procedure to tighten the rockers on the base circle and the spring is compressing. That's your proof that the push rod is for some reason too long. Whether it's too long, not seated, not compressing the lifter, etc.. you'll have to check.
As for not torquing. You'll have to pull the rocker stand off and look at the threads and the bolt to see if it's stripped. Hard to guess over the computer what's going on there.
Old 03-12-2019, 07:10 AM
Ls7colorado's Avatar
Id pull the pushord out and compare it to another.
Also make sure that the rocker arm shaft is not flipped upside down
Old 03-12-2019, 09:35 PM
chr45gt2's Avatar
I pulled all the rockers off that side, checked the pushrods, cleaned all the sealant off, and put some new sealant on. Everything torqued up fine after I did this.
Old 03-12-2019, 10:06 PM
Nice!
Old 03-12-2019, 10:27 PM
vorteciroc's Avatar
Received 1,226 Likes on 859 Posts
Wow! Random...
