(Leroy corvette) bald eagle cam?
Old Apr 17, 2019 | 06:13 PM
  #81
My pontiac's Avatar
Just a update. Had car dynoed today 408hp 372tq. Car dynoed last year at 347hp with stock cam
Old Apr 18, 2019 | 12:14 AM
  #82
C5SixSpeedZ51's Avatar
Congrats brother, those are some good #'s out of your setup. Later on Add a
Set of cnc heads and a fast Intake and Yould be on up there on power for sure. 👍 Does it feel and drive good?
Old Apr 18, 2019 | 03:55 AM
  #83
Kjduvall's Avatar
Those are some good numbers for stock heads. I don't care what any one calls this cam. The spec's look pretty good to me. Congratulations !!
Old Apr 18, 2019 | 08:10 AM
  #84
My pontiac's Avatar
Ya im happy with those numbers. Seem to drive good.
Old Apr 18, 2019 | 02:51 PM
  #85
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Killer!!
Old Apr 19, 2019 | 02:00 PM
  #86
Jay Fisher's Avatar
I agree on the Titan 4. I am currently doing a Titan 5 in my 06 GTO with MMS 223 heads and a Mamofied Fast102
Old Apr 19, 2019 | 04:01 PM
  #87
huggerls1's Avatar
good numbers, I just got my car dyno'd on the 5th. I have another cam people get upset over (sloppy stage 2) but I also put on stock 243s and made 416 HP/ 400 TQ on a dynojet.
99 SS 6 speed.
Old Feb 22, 2020 | 02:47 PM
  #88
BlackFbo's Avatar
How is the low end and midrange and do you know what peak rpm torque and hp were at? Also looking at getting this cam but idk if I want it or the torquer v2
Old Feb 23, 2020 | 02:32 PM
  #89
The bald eagle has a much longer power band and will likely make about the same peak hp and tq as the tv2 and in a manual trans drive better. Id expect the power difference between the 2 bald eagle start at about 2600 and tv2 about 2800-3k
Based off some installs and personal driving we have done.
Old Feb 23, 2020 | 03:53 PM
  #90
BlackFbo's Avatar
Thank you for the reply! Also, thank you for the fast shipping on the hardware for my heads that I recently purchased! WS6store.
Old Feb 23, 2020 | 06:25 PM
  #91
No problem!
Our high lift asa is slightly better vs the bald eagle, but we also designed it to be like that and still use the same components. The bald eagle is still a great cam and the best mid range cam between the low 220s cams and the 233/239 upper end more aggressive cams from ive personally and professionally seen. Our high lift asa you can say the same for. It exceeded my expectations which is a good thing.
The torquer cams are really only still alive due to the length of time they have been out. The TSP new design is much better than the old one, but still there are much better cams that give you everything you need and still the sound of the larger cams
If you havent gotten one yet, give us a shout about our high lift asa cam. We have an NA and boost version available and can usually work out a good deal on cam or cam kit!
1 877 232 9701
Old Jun 8, 2020 | 01:00 AM
  #92
James Martin's Avatar
Default ??
Does anyone have the bald eagle cam in a ls1? How do u like it? This is going in a 2000 trans am, t56, ls6 intake, lt headers, borla back. This is first time putting a cam in a car so i dont know what to expect out of it. Is there a better cam for my set up. Thanks
I'm looking at same cam for my '98 SS. I have same setup as you, have you gotten it done yet? Curious how the chop and gains are and streetability.
Old Jun 8, 2020 | 03:50 PM
  #93
My pontiac's Avatar
drives good, gained about 60hp from the cam sounds good to. i cant complain about it.
Old Jul 9, 2021 | 09:57 PM
  #94
WhosNXT's Avatar
Cleetus now has a El Camino with a full body that runs 7s. So all the hate for Leroy not having a body doesn’t really matter now. He will be in the 6s soon.
