'02 WS6 Build
Old Feb 25, 2020 | 11:07 AM
  #161
StealthFormula's Avatar
That's great news. Hopefully you had some brewskis while celebrating.
Old Feb 25, 2020 | 07:35 PM
  #162
LilJayV10's Avatar
Good thing you actually did some checking instead of throwing a bunch of parts, time and money on a problem didn't exist....
Old Feb 28, 2020 | 08:03 PM
  #163
blsnelling's Avatar
Originally Posted by SLP IROC-Z
lets hear it warmed up!
Which one do you prefer?
800 RPMs
850 RPMs
900 RPMs
Old Feb 29, 2020 | 07:11 AM
  #164
SLP IROC-Z's Avatar
I like 800. Sounds mint! Are you going to put it on a dyno soon?
Old Feb 29, 2020 | 11:56 AM
  #165
blsnelling's Avatar
Thank you. For now, I'm working with PatG through the mail. I'm logging and he's adjusting the tune. I've installed a wideband O2 to assist in that. Eventually, I'd love to get it on a dyno for some final tweaking and numbers.
Old Feb 29, 2020 | 10:02 PM
  #166
00pooterSS's Avatar
800 all the way
Old Feb 29, 2020 | 11:47 PM
  #167
blsnelling's Avatar
Should I try 750?
Old Mar 1, 2020 | 05:32 AM
  #168
SLP IROC-Z's Avatar
go for it
Old Mar 2, 2020 | 12:26 PM
  #169
I think 850rpm sounds the best of the 3, 800 is a little slow for me, I think 825 would be the hot ticket from a sound perspective. Super subjective however. Anyways, test each idle rpm out by going down the road and pushing the clutch in as you slow to a stop (do the same in reverse in a parking lot) and by doing tight manuevers in a parking lot with both the AC on and off. If they all pass the test then you can base your idle selection off the sound. You may find you prefer the sound of one but prefer the driveability or manner of another.
Old Mar 2, 2020 | 01:18 PM
  #170
Darth_V8r's Avatar
Moderator
Agreed. Sometimes a faster idle makes for better overall driving experience at the expense of sounding slightly less cool. You can always rock a mullet...
Old Mar 5, 2020 | 07:15 AM
  #171
blsnelling's Avatar
I desperately need a Tick clutch master cylinder. It will NOT shift any faster.
Old Mar 5, 2020 | 07:54 AM
  #172
mintws6's Avatar
What kind of clutch did you put in it? Tick does help but I think clutch helps more, I went Monster stage 3 with the light weight fly wheel and a tick master. Shifting is good but adjustment of the master is a pain in the ***.
Old Mar 5, 2020 | 07:58 AM
  #173
blsnelling's Avatar
It's original with only 22K on it.
Old Mar 5, 2020 | 08:00 AM
  #174
SLP IROC-Z's Avatar
https://youtu.be/O2H2ZvdwWwY
I would throw a gmpp master and slave in it.
Old Mar 5, 2020 | 08:12 AM
  #175
blsnelling's Avatar
I'll have to read up on that.
Old Mar 5, 2020 | 08:13 AM
  #176
SLP IROC-Z's Avatar
When they start acting up like that its best to just replace both. Been there done that
Old Mar 5, 2020 | 08:20 AM
  #177
blsnelling's Avatar
Is the GMPP part an upgraded unit or simply a new OEM replacement?. PN GMP12570277?
