Intake Valve Pitting
almost every intake valve had this horrible pitting on the heads of the valves. they don't look like deposits of any kind, and i couldn't imagine they were cast this poorly. the bottom of the heads are actually fine and look nothing like this. valve faces are also worn, very slightly concave.
What say ye, ls1tech? what could have caused this, and are these still usable?
someone also mentioned that chlorine can cause the stainless steel to pit. I'm sure other chemicals can as well. wonder if something corrosive would be the cause? if so, how did it did it get in there?
there's no corossion on the stems. It all starts right at the filet and is all over the head. Some are worse than others.
my response was in line with finding an answer as to why they pitted. I don't believe it was from water sitting in the ports, unless it was saltwater. Even then... there was no rust on the valves. Just carbon and varnish, like i said. Unless the previous owner cleaned them up and used them.
WELL i guess LLLosing it and my other associate have the best theories as to why stainless intake valves would pit like this.
Thanks anyway.
The question is... chloride from what? Did some idiot pour bleach in the intake ports, lol?
dimpled for moar CFM's of uurrrflow.
There are all sorts of things that they put in gasoline besides the pure hydrocarbons.
