LQ4 Build Questions
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I have a iron 6.0 LQ4 that I'm building. Going to make it 408.
The power goals are 550 rwhp, want torque and throttle response for frequent drivability.
Tremec 6 speed.
1 7/8 LT headers, 3" dual all the way.
I'm an old school guy trying to get caught up in this world. Here are my questions that I'd like your opinions on:
I acquired a set of 862 heads that have been CNC'd. I don't know who did them, but I measured them. They are fresh with new valves/springs.
Chambers 67cc
Int. runners 233cc
Exh runners 87cc
Int Valve 2.05
Exh Valve 1.56
How would these heads fit in my plan, or do I pass them on and get different? If so, what?
Also, which intake would be best for this? How well do the single plane 4150 type flanges work?
Camshaft tbd.
Thanks in advance for your comments.
Tremec 6 speed.
Chambers 67cc
Int. runners 233cc
Exh runners 87cc
Int Valve 2.05
Exh Valve 1.56
Camshaft tbd.
As G stated, the 706/862 castings are the same dimensionally. Different casting process, but numerically/dimensionally the same. Here’s the numbers as cast...
Combustion Chamber Volume: 61.15cc
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 1.89 inches
Exhaust Valve Diameter: 1.55 inches
The following users liked this post:
G Atsma (01-23-2020)
So with the mods that have been done to these heads, are the “hogged” out dimensions beneficial for my goals? How do these specs compare to other aftermarket heads? Just trying to understand what the goal was for the shop that did this work. Cosmetically, they are gorgeous....
