Crankshaft front oil seal removal
I'm in the process of installing an ATI Superdamper and upon removal of my stock crank pulley, I noticed that the crankshaft front oil seal is looking pretty bad. I would like to replace this seal, but what is the best way to remove the seal from the timing cover without taking the timing cover off? I fought with it a little tonight, but didn't get anywhere. Any tips on getting that thing out?
wrencher
You can use a screw driver to carefullly pry it out. Once you get it to move a little it'll pop right out. Make sure to put some grease on the lip of the new seal so as it doesn't start up dry.
To replace the front seal, you have to take the timing cover off. There's no way around it. The seal is taken off from the back side and installed the same way. You'd have to take off the crank pulley, water pump, then unbolt the timing cover.
BADA BING BADA BOOM!!!!!!
I have a tool to press the seal into the timing cover... just a matter of getting this old one out.
Richie, you mentioned a seal pulling tool. Is this something generic? Or a GM tool?
As for using a screwdriver, do I need to use a small one to pry between the outer diameter of the seal and the timing cover? Is that the best way to do it?
Originally Posted by P Mack
I have always heard to not lube the new seal up. I didn't and no leaks so far.
Yes, the seals are to be installed dry. They have teflon in them that gets transfered during initial startup. By using a lube the teflon will not transfer and will hinder the sealing process.
Originally Posted by Richie Carbone
The seal CAN be removed with the cover in place, get yourself a seal pulling tool and see if you can find someone that has the LS1 specific Kent Moore front seal installer. The tool is designed to install the seal with the cover bolted to the motor.
Picked up a seal remover/puller from Auto Zone tonight and pulled that front oil seal out with no problem. Tried pulling on the seal from head on, but I couldn't ever get the puller to grip the seal. Approached the seal at an angle, using the crank as leverage and the seal popped right out. When I saw that I was able to get a grip doing it at an angle, I got 3 shop rags and wrapped around the crank snout and proceeded to use the puller. No scuffs or marks on the crank or timing cover... and the seal is out -- perfecto.
Sure glad I didn't have to take the water pump off. Thanks guys.
This thread is about a Gen III LS, not a Gen II LT. LS engines do not use optispark. They are coil-on-plug
