Hylift Johnson 2148SE
Any issues or comments?
I’ve finished the LS3 short block for my C5 and want to replace the bad set of LS7 lifters that currently reside in the LS1 that’s coming out.
I’ll either use these or the drop in Morels.
Thanks
Ron
This is why you can get Hylift Johnson on ebay for $120 to $300.
https://johnsonlifters.com/AboutUs/WarrantyClaim.aspx
I'd pay $400 more for a part thats laser etched with the company name and doesn't have BS everywhere about there origin, thats just me.
I bought some Hylift HA2148SE from
https://jamsionline.com/.
I did find them cheaper from an over sea site, but the picture they showed them all bright --colored. The ones I got are ringed with two black areas and look well made.
I have not installed them yet. There is a video on the US manufacturing plant, in an old thread. Not the video but close
https://ls1tech.com/forums/generatio...od-ones-3.html
Here is the box they came in. Notice it says Made in the USA.
Hope this helps.
Ask the guy from morel that used to post on here. Ask BTR. Or search. Hylift is an old company that can make lifters. It's been said that they don't though.
Realize this is not my opinion. Its based on what some well known people in the business have said.
I'm just the mailman. You can buy and believe whatever you want.
For me. If I'm tight on money I'll go for the $80 hylifts and not the $350 hylifts. Same part number. Same picture. Not sure what the metrics are on that pricing strategy.
Here is the YouTube link that shows the machining of the lifter.
youtube.com/watch?v=lLx_2UKcjS4
To make the link work, copy and paste. A direct link could not show up.
https://www.johnsonlifters.com/products.aspx
are knockoff products that copy or imitate the physical appearance of our products but are manufactured in China and other Countries. They Sell Imported products.
Again, not my words. Just my observation.
agree and there maybe a small bit of truth to it ! Or Hylift Topline would sue Johnson Lifters for slander .
But, I guess not.
So the GM LS7 12499225 are what's in both the Nova and the Vette. The ones in the vette since 2012 bleed down so fast that you can watch them when cranking the engine during a compression test. The ones in the Nova don't do that. Hence the desire to replace them. I should not the Vette has AFR heads with AFR upgraded springs by PAC and are 425 over the nose. Helps control the heavier valves and the YT Ultra Heavy rockers.....
Those came from a GM dealer. I paid $119, was the going rate back then. I see now they are $250+
Morel seem to still be available for $200 or so.
Anything better, such as slow leak versions are $400 plus. Nothing preventing a guy from spending $1200 on lifters.
So, prob bend over and buy a better lifter.
As far as the diatribe above about China vs US made, who the hell knows. I did some poking around as well.
It's all fake news now.
Ron
QUOTE
With those spring & cam numbers you are going to want the 2148SE, they will work perfectly for your setup.
I have attached a photo of 2148 vs 2148SE, they use the same casting material.
Notable difference is the internals being tighter, “c” clip retainer , & black oxide body on the 2148SE.
They are good up to 160 lbs of seat pressure & they will perform up to 6800 rpms with your cam setup.
Hope this helps & have a great day.
Thanks ,
Dave Ewert
Hy-Lift Johnson Co.
800-441-1400 x 611
I have some 2148 already I may have to sell those, I'm curious what would happen if I used them instead of the 2148SE? I decided on and purchasing at bit milder camshaft now, I wont be reving past 6500 rpm with same .585 lift and same 392 lbs/in rate dual PAC springs as before in my LS1.
Reply Quote from Dave at Hylift Topline
Hello Tim,
I understand what you are saying. As long as your seat spring pressure isn’t above 130 lbs & you don’t over rev beyond 6500 rpm our 2148 will work just fine.
If either are exceded you will collapse lifters in the stuck down position.
Thanks & best of luck with your engine
Dave Ewet
and (both lifters have forged steel bodies)
