Full 5.3 rebuild won’t fire
so I got a 2000 5.3 out of a Chevy Silverado with a blown head gasket, tore it all the way down to the block and fully rebuilt it. Resurfaced the heads, honed and decked the block. All new bearings and seals, put in a Brian tooley racing torque cam and switched to flat top pistons. Got it all put together and in my Toyota pick up. Wiring with a Holley terminator x system and Holley fuel rails. I have between 140-160psi of compression on each cylinder, also have fuel and spark. Whenever I try to fire with the base tube the Holley came up with nothing happens, so I dropped the timing down from 15 to 14.3 to see if it was that and got it to fire a little but not run. When I have the throttle open I can hear popping coming from inside the engine. This leads me to believe that my timing is off and my intake valves are still open when it’s igniting. Would that be a correct assumption? I thought I lined my cam and crank up dot to dot but maybe I was ever so slightly off? Would that be the cause of this? This is my first time doing anything like this. Any advice would be appreciated. I’ll try to attach the video of the firing that I did get, won’t let me upload from my phone. I’ll try to get it to the computer to upload
First thing I would do is make sure your Holley is set for the correct reluctor ring 24x or 58x depending on witch crank you have.
as far as the Holley being set up for the correct reluctor ring, I’m also 99% sure it was set up for the 24x sensor which is what I have.
