Can I pass smog with bad lifter?
Old May 6, 2021 | 02:28 AM
Bakir Bakir's Avatar
Default Can I pass smog with bad lifter?
Long story short my lifter went out 3 months back and I let my car sit. I only drove it about 20 miles on the bad lifter but I was wondering if I could pass smog in ca with a bad lifter? Will it make it run rich or worst or sum? I I took valve covers off but nothing looked bad so I put it back together.i don’t remeber how my oil pressure was but it was defiantly Atleast 50 when started up. Also will I kill my engine or will the cam only be damaged?
thankkksss
Old May 6, 2021 | 06:47 AM
MuhThugga's Avatar
Fix your damn engine.
Old May 6, 2021 | 10:21 AM
^^^^^^^ THlS, BIG TIME!! You might be scattering shards throughout your engine, which you DO NOT WANT!!
Passing smog is the LEAST of your worries right now. Wise up!!
Old May 6, 2021 | 01:08 PM
It because I want to change my cam but I need to smog first
Old May 6, 2021 | 03:14 PM
Not gonna happen if you don't want to potentially wreck your engine. Which cam going in? If not too gnarly, it might pass anyway...
Old May 7, 2021 | 10:43 AM
MuhThugga's Avatar
Let's assume that you don't damage your engine and take it for a smog check. Do you really think the techs aren't going to notice your engine sounding like a road crew breaking concrete?
Old May 7, 2021 | 04:51 PM
1FastBrick's Avatar
Does it have a check engine light on?
Old May 7, 2021 | 05:19 PM
01CamaroSSTx's Avatar
It amazes me how often I see vehicles with an inspection sticker emitting large amounts of blue smoke from the tail pipe. Obviously these are people that have neglected their engines but they can pass an emissions test no problem.
BTW...OP...Fix your engine. It will cost you more in the long run if you continue to drive in its current condition. It could be anything from a clogged lifter, to a worn camshaft lobe, pushrod, valve, valve spring or a worn or loose rocker arm.
Old May 7, 2021 | 05:47 PM
1FastBrick's Avatar
1996 and newer vehicles no longer require a dyno/sniffer test. Just the OBD2 test. And it does take a snapshot of the ECU calibration numbers...
Some pass/some don't... but they dont mess around if they do catch you.
So as long as they are not blowing heavy smoke when they come in, they will get a pass as long as the emission test are ready and passed and they pass the visual inspection and all required emission devices are still in place and do not appear to have been tampered with.
If the catylic converts were replaced, the number has to be visible and correct for that application.
If you have replacement/performance parts they better have the E/O carb number so the tech can look it up and verify it. It will be documented at the time of inspection.
Old May 7, 2021 | 06:30 PM
Biebs's Avatar
check engine light = off - it will pass smog test
Old May 7, 2021 | 06:48 PM
RedXray's Avatar
May be easier to move to a communist free state like South Carolina...
we don't have inspections as most of our cars are sitting on cinder blocks anyways
Old May 9, 2021 | 10:59 PM
wannafbody's Avatar
That depends on the particular state.
