Camapalooza Camshaft Dyno Test Marathon!
LS1Tech Sponsor
Like dyno tests? Well, this is the right thread.
The tests subjects name is "Krusty". Krusty is a Junkyard sourced LY6 6 liter LS based engine that we did not even give the courtesy of a bath. The engine looked to be in good shape and took a beating like a champ! With well over 100 dyno pulls, about 25 cams, 4 intakes and 3 sets of heads, Krusty never skipped a beat or even whimpered! Many of these pulls were to 7500 RPM! The only casualties were a broken ARP head stud and a killed MSD plug wire.
Popular Reply
07-02-2021, 02:21 PM
Location: Coast of San Mateo County Between Pacifica & HMB
Why do some guys ALWAYS have to bring in turbos and/or blowers into a cam thread???
I like turbos and blowers but they DON'T need to be inserted into a Vendors thread
about NA Cams Testing info.
Just my .02
Just my .02
LS1Tech Sponsor
About Krusty:
6 liter LS based Truck Engine
LY6 shortblock – Stock/Used approx. 50k miles
-9cc ish pistons – Stock LY6
Heads used:
Krusty's stock 823 rectangle port heads
706 5.3 cathedral port heads (61cc) – Stock/Used
243 cathedral port heads - unported, but with a fresh multi-angle performance valve job
Compression with 823 heads: 9.6:1
Compression with 706 heads: 10.36:1
Compression with 243 heads: 10:1
Intakes:
TBSS Intake w/92mm Ebay throttle body
Stock LS3 Intake
Edelbrock Super Victor Cathederal Port
Holley 300-291 split design single plane intake
Injectors used:
Snake Eater 1500cc injectors (used in cathedral port test with TBSS
Stock LS3 injectors (used in LY6 intake tests)
Single Plane Testing performed with a Edelbrock Super Victor and 950 CFM Holley 4150
2” 4 into 1 headers provided by American Racing Headers
EFI ECU Holley Dominator EFI
Carburetor tests: Some with Dominator EFI and some with the MSD 6014
NGK TR6 spark plugs and a used set of MSD wires
10w30 Signature Series motor oil courtesy of independent Amsoil distributor NavyBlue210
All tests performed back-to-back on Muscle Machining’s 902 Superflow Dyno
All EFI Tuning by DrTuneEmAll Nate Kuhl of NK Performance.
Heads used:
Intakes:
Stock LS3 Intake
Injectors used:
The following users liked this post:
NSFW (06-30-2021)
LS1Tech Sponsor
So, who do we start with? Let's start with our best selling cam for the LS1.
Titan 4 LS1 Camshaft
#03-01-0013
Duration at .050": 227/232
113 Lobe Center Angle with a 109 Intake Centerline
Lift with 1.7 Rocker Arm Ratio: .612"/.595"
People just love this camshaft. It makes good power, has a defined lope but is easy to drive. It has been a best seller for a long time.
#03-01-0013
The following 3 users liked this post by CAMMOTION PERF:
IF it isn't TOO much trouble, could you post the cam specs with each test only to avoid having to go to your site to look them up. OK, laziness has triumphed... lol
Also- are you going to test your truck cams? If so start the charts at 2000 RPM to track low-speed torque. Thanks in advance!
speedtigger (07-01-2021)
I like where this is going!
For the lazy, and because I had to look it up too....
Titan 4: 227/232, 113+4
3.5 degrees of overlap @ 050, 42.5 IVC
The following 2 users liked this post by Kingc8r:
speedtigger (07-01-2021), Union Racing (07-01-2021)
Thanks Cammotion, this should be good. Appreciate you guys taking the time to post up.
LS1Tech Sponsor
Next up? Our most popular LS3 camshaft.
Titan 3 LS3 Camshaft
#03-01-0018
Duration at .050": 227/237
113 Lobe Center Angle with a 109.5 Intake Centerline
Lift with 1.7 Rocker Arm Ratio: .621"/.604"
This camshaft is popular for obvious reasons. It makes great gains over the stock LS3 cam, has a great lope at idle, but still drives nice.
If you are wondering why it gained less than the Titan 4 LS1 cam did over the stock OEM cam, it is because the OEM LS3 camshaft is quite a bit more powerful than the LS1 camshaft (#12561701).
#03-01-0018
LS1Tech Sponsor
Time for some big dogs.
Titan King LS1 Camshaft
#03-01-0015
Duration at .050: 236/244
112 Lobe Center Angle with a 109 Intake Centerline
This one is nasty. Super choppy rough idle and all the power and attitude.
#03-01-0015
G Atsma (07-01-2021)
This thread is awesome
The following 2 users liked this post by Bob570:
NAVYBLUE210 (07-02-2021), speedtigger (07-01-2021)
The following 6 users liked this post by Che70velle:
Darth_V8r (07-07-2021), G Atsma (07-01-2021), Jimbo1367 (07-05-2021), low2001gmc (07-02-2021), speedtigger (07-01-2021), and 1 others liked this post.
That's why I paired a mild cam with my good heads.
I'm old though ... maybe young guys think it's fun to get their clocks cleaned at stoplights by a car that's quieter, idles better and gets better fuel economy. :-)
The following 4 users liked this post by grubinski:
And yet other old guys who prefer N/A setups will use the milder cam with more low and midrange torque to clean the clocks of grossly over-cammed, peaky builds because their owners HAD to have shaking-like-a-dog-crapping-peach-seeds chopping cam so the peanut gallery can hear what great engine builders they are.... lol
The following 7 users liked this post by G Atsma:
Blac94z28 (01-25-2024), grubinski (07-02-2021), Jake Wade (07-02-2021), Ken-02Z28A4 (08-19-2021), LilJayV10 (07-09-2021), and 2 others liked this post.
G Atsma (07-02-2021)
The following 3 users liked this post by G Atsma:
