Will a LSx cam sprocket fit a BBC?
This is a super weird question so I’m not expecting anyone to know, but in the off chance that someone might, will a cam sprocket from a 3 bolt LS cam physically bolt to a BBC cam? Do they share the some tooth count, and chain specs? An example sprocket would be the 12586481. I’m trying to add 4x cam signal to a BBC, kits are out there but not in stock. Trying to get creative!
You could convert to a Vortec style distributor with the cam sync built in. I believe it will only get you a 1x cam signal though. I'm not sure if they make an aftermarket dual sync distributor setup for 4x.
Personally I think the 4-bolt setup could be relatively easily FAKED off of standard BBC parts.
I'd get yerbasic good-quality BBC sprocket, some steel stock of the appropriate thickness (could be anywhere between 1/8" and 1/4" depending on the particular sprocket you started out with), and cut out acoupla half-moons and maybe acoupla little squares; drill and countersink some screw holes; drill and tap the sprocket to match the screw holes; and bolt the pieces on there with little short flat-head Allen or torx screws. Hardest part would be getting them phased right. Doesn't seem that it would be all that critical though, since all that the cam stuff does, is tell the ECM which cylinder it's on. Actual "timing" is determined by the crank gear.
Not sure what the mounting for the [mr.spock]sen-SORE[/mr.spock] would look like exactly, but as long as it didn't interfere with the water pump, it couldn't be too terribly hard.
The "4X" is not the reluctor. They are either 58X or 24X. You are referring to the 4X cam sensor phasing sprocket. They are either 1X or 4X.
The following users liked this post:
G Atsma (10-02-2021)
It’s going to be ran with a Terminator X, but with coil-near-plug and no distributor. I’ll probably find a junked motor at the machine shop and compare to what I have already.
And yes, Chevy makes a BBC cover that has the sensors positioned for 58x/4x pickups.
