Modern 233/239 cam alternatives
I’m looking what benefits there will be switching to a more modern cam profile.
currently I have tsp 233/239 111LSA .600 .600
engine setup:
Stock ls1 bottom end limited at 7000rpm
AI 226 Cnc heads
victor jr intake
holley 4bbl throttle body
deka 60lb injectors
ws6 store rockers
Holley terminator x
t56 magnum transmission
Long tubes
car is a 1969 camaro idles at 770rpm
future mod will be a dual plane intake manifold that I will weld injector bungs on to to give a little more midrange. All the dynos I have seen show no losses below 7000rpm on 346cid applications. Also going to 4.1 from 3.73.
summit offers a stage 3 with similar specs
231/242 113+3, .600/.600 Lift.
are there any mid range benefits to switching to a more modern profile? I’m fairly happy with the 233/239 but want to hear any suggestions.
engine setup:
AI 226 Cnc heads
victor jr intake
deka 60lb injectors
ws6 store rockers
Holley terminator x
Long tubes
Seems like you have some really nice cylinder heads on there, with a great intake. Why not just call around and start asking what companies opinions are and have them each spec you out a camshaft for your setup.
Texas Speed and Performance 512-863-0900
Martin Smallwood Smallwood Race Development 864-723-2892
Brian Tooley Racing (888) 959-8865
Cam Motion 1-225-926-6110
Hope that helps you out a little I am sure some of these guys can point you in the right direction, I have been on the phone with each of them here th past few weeks trying to put together a new build and get their ideas on combos and camshaft designs. Best of luck.
I personally wouldn't change it. Some of the older cam designs/specs out perform the new stuff....
engine setup:
AI 226 Cnc heads
victor jr intake
deka 60lb injectors
ws6 store rockers
Holley terminator x
Long tubes
engine setup:
AI 226 Cnc heads
victor jr intake
deka 60lb injectors
ws6 store rockers
Holley terminator x
Long tubes
The following users liked this post:
G Atsma (10-05-2021)
That intake will limit upper RPMs I used to be for them, but have seen some negative data on them.
02*C5 (10-06-2021)
sounds like I will just stick the with 233/239 as it has a proven good history.
I'm running the comp low shock drift cam It's a 233-243-114 LSA and its advertised to work with stock or LS6 springs if you look at the description on the website they only recommend changing the timing chain if your engine has a lot of miles, It's safe way past 7500 RPM (That's where I set my limiter) because the lobes were designed on a spin-tron I have one in my junkyard LQ9 and I've been bouncing it off the 7,500 RPM limiter since I put it in there. I used summit racing LS6 springs and BTR hardened pushrods a bit longer than stock to strengthen the valve train Even further. I imagine if I change the oil every once in awhile it should last about a million miles. It is so smooth there is absolutely no valvetrain noise and no float at all whatsoever I'm really happy with it. I have another thread about it already with idle videos etc
