Ls7 lifter install giving me trouble
I had trouble removing the factory lifters which I believe were all stuck in the bore and I had I had use pliers to remove them. Some were harder thsn others to remove.
Today I made sure the bore was clean and I put assembly lube on the bore, the new ls7 lifters were soaked in oil.
I install them into the new oem trays and try to push them down into the bore and many just will not go down. Why will the lifters in the tray not freely go in? A few of the stuck ones I could tap down with a small piece of wood and hammer. Depending on me turning over the engine by hand. Some of the stuck ones I even tried to remove and gave up, they were fighting me so hard. Not a single ls7 lifter could freely move in the bore it was either pull them out with pliers or knock them down with a hammer and wood.
What is wrong here? what can I do?
ideas and thoughts appreciated.
thank you
Didn't feel bad the small are you can reach your finger in
ETA: I only installed two trays(8) lifters on one side today.
EDIT!!!! An additional thing is this; as posted by another member, many times the reason they won't come out is because the lifter has 'spread' at the 2 axle mount points. It is also possible that an axle has 'walked' sideways, which would impede removal, and cause damage if forced. You may be able to CAREFULLY install an OLD lifter upside down (roller wheel facing up), and gently tap it down into the lifter bore. Just be very carefull how far you tap it in, and how hard you tap on it. This method MAY 'scrape' enough of the high points down to allow the new lifter to be installed correctly. Should be a shiny spot where the burr was/is. NOTE!!! If it buggers up the lifter body, it will damage the lifter bore on removal, too!! So that method would only be viable on one lifter bore,, IF that scenario takes place. The LS engines oil the lifters first, one feature on them I personally do not care for. Any significant damage there allows for oil pressure to bleed off, which is not good!!! You have a serious situation there. I hope the lifters you did get installed went in easily, which is the only way they should!!! Best of luck to you......
I don't see any expansion of the stockers or broken parts on them. The oem ones were tough to get out and I had to use pliers and a few pulls to try and get them up. I knew I was going with new lifters so I didn't really worry about ruining the top part of the cup with the pliers.
This is an iron block gen 3 5.3 truck engine
Thank you all and please help me get this project working. Appreciate the help
As long as I lube the **** out of the bore with wd40 and get them in with assembly lube I'm all good as long as I can get the tray down with them right? Some are definitely more held up than others trying to slide in. As long as they get into the bore and the tray fits, can I rely on the cam lobe and the pushrods/rocker arm to make it work on a running engine?
Sorry for the rookie questions, this is my first LS build and I was trying my best with my nephew. I wanted the kid to be proud of what we put together.
I hope I don't fail him.
As mentioned check the Bore I.D. to the New lifter O.D. to see where you are.
Worst case You may need to run a 7/8 Ball hone through the lifter bores to clean them up. If that's the case, you will have to tear the block down and clean it thoroughly afterwards. you do not want any of the abrasive in the motor oil gallies or on the parts. It will destroy the engine.
