New Timing chain - Is this normal???
I bought one like that recently- luckily, my buddy had another new one handy, so I just swapped it.
Sometimes decking the block can cause a bit of slack, but that looks like a ton.
It is frustrating to buy a chain and have it this slack. It was brand new in a GM bag. The trouble is as far as I can see, there's nothing to stop me wasting the same amount of money again to find exactly the same issue
I can't see what I can do about it.
Decking the block can't affect anything to do with the timing chain. It doesn't move the cam close to the crank. Which is the ONLY possible block machine work effect that could affect the chain tension; something such as align-boring the main bearing bore. But even that only moves the crank a couple of .001"s closer to the cam, NOWHERE NEAR the amount of slop you've got there. I've seen 200k mile factory motors that had less than that. Something is BIG TIME WRONG with your setup, but it's not completely obvious what it is.
What chains and sprocket sets do you have? Have you tried a TIMING SET, rather than merely putting a new random chain on some random sprockets?
As mentioned, there are "tensioners" that actually "tension" the chain with spring pressure, but they're well and widely known to be a long-term reliability issue. What you have there is far better.
As you can also see the regular guys answer wasn't correct.
These timing marks are aligned. It looks to have the same amount of slack if you look at the distance between the chain and tensioner bolt.
You should align it dot to dot, it's easier.
Just to add, I haven't lined it dot to dot yet as it is only temporarily fitted whilst I wait for the cam thrust plate screws.
Any idea what exactly the material spec is (other than just looking like plastic)?
Yes, sorry- been a long week.
