Help chirping noise!!
Old Mar 4, 2023 | 01:41 PM
Tommy42088's Avatar
BTR GEN III & IV TRUCK CAM - STAGE 3 - V2 - BTR31824100 (218/224 .553/.553 110+0)
this is the cam that's in my truck, mind you I do spray this truck with up to 200 shot of nitrous. I usually keep it at 150 tho. Any suggestions on a different cam if I do need to replace it or should I keep the same cam
Old Mar 4, 2023 | 01:43 PM
Tommy42088's Avatar
100% truth there.
I would never put chinese junk in my truck lol, i always get name brand stuff. Cheap stuff never last, especially with nitrous
Old Mar 4, 2023 | 05:09 PM
Tommy42088's Avatar
Old Mar 4, 2023 | 05:11 PM
Tommy42088's Avatar
Old Mar 4, 2023 | 05:15 PM
Tommy42088's Avatar
I dont see any noticeable damage anywhere, only thing i do notice is that the lifters are very loose in the trays. They fall right out of the trays
Old Mar 4, 2023 | 05:17 PM
Tommy42088's Avatar
Slightly scratched, nothing drastic
Old Mar 4, 2023 | 05:18 PM
Tommy42088's Avatar
BTW, I do hope you installed new trays with your LS7 lifters. Make that new GM trays, not Chinese junk trays.....
opinion please on below pictures?
Old Mar 4, 2023 | 05:19 PM
Tommy42088's Avatar
Originally Posted by G Atsma
It's not head-related. The bolts used depend on the block, the older of which have deeper head bolt holes.
Whatever you are using in your presnt block are the ones used on any other head you put on it.
opinion on pictures please?
Old Mar 4, 2023 | 05:27 PM
pdxmotorhead's Avatar
The important thing is looking down in the engine and seeing if you have a damaged cam lobe,
I have also seen an engine "chirp" when one of the cam bearings walked out..
A inexpensive bore scope is your friend on this one..
Can you see the cam looking down the lifter bores?
Old Mar 4, 2023 | 06:28 PM
Tommy42088's Avatar
I looked through the holes at the cam and i dont see any damage on the cam. What should I be looking at with the bore scope
Old Mar 4, 2023 | 06:36 PM
Tommy42088's Avatar
The sound was coming from the passenger head, that's what's crazy about it
Old Mar 5, 2023 | 12:06 PM
  #32
Tommy42088's Avatar
Sounds kind of crazy but I actually think it's the valves and springs. There's alot of build up on that side and there's no signs of any real damage
Old Mar 5, 2023 | 04:39 PM
  #33
Gene Cheeseman's Avatar
So thats one side right?
Did you take both heads off?
Old Mar 5, 2023 | 05:40 PM
  #34
grinder11's Avatar
What do you mean by "a lot of buildup"??
Old Mar 5, 2023 | 05:58 PM
  #35
Tommy42088's Avatar
yes I removed both heads, the lifter trays are very loose on both sides but the drivers head is very clean and fresh looking where as the passenger head has alot of like black carbon build up around the valves and the springs
Old Mar 5, 2023 | 05:59 PM
  #36
Tommy42088's Avatar
the springs have black carbon looking build up on them where as the drivers side is very clean.
also the guy i got the motor from supposedly port, polished and milled the heads and I'm no machinist but i do not see any signs of any port work so i think im going to bring the heads to a machine shop and have them check them and confirm the port work or do the port work if its not done and also from my understanding milling is a must on 243 heads on a 5.3 so I'll get that looked at too
Old Mar 5, 2023 | 08:06 PM
  #37
All LS engines will have this “clean side and dirty side” head under the valve covers. It’s from the way the PCV pulls clean air through the engine. First time I saw this, I thought the engine in front of me had a new head on one side.
Old Mar 5, 2023 | 08:09 PM
  #38
Tommy42088's Avatar
oh wow, I don't know what's going in. I can't find any damage anywhere. Besides the loose trays
Old Mar 5, 2023 | 08:23 PM
  #39
The trays should hold the lifters so snugly, that the lifters won’t fall out of them when removed, even in a 150k mile engine. You should try and find a new set of GM lifter trays. Don’t settle for aftermarket trays, as they aren’t made from the same product, and will wear quickly. The loose trays will allow the lifters to turn (instead of running exactly square) a tad on the cam lobe. This will cause lobe and wheel scarring at a minimum from the heat that is produced, from not staying square on the lobe. Looks to me from your pics, that this is your exact issue.
Old Mar 5, 2023 | 10:50 PM
  #40
Tommy42088's Avatar
hopefully so, I ordered the trays and lifters from summit. I figured they would sell me quality parts.
when I picked up the trays none of the lifters came out. I had to use a magnet to remove them from the block.
