Johnson 2116LSR lifter preload question
I always measure for 0 lash with my rockers torqued down, then add pre-load.
I also measure for all 16 pushrods and write it down for each one, I've always had to order at least 2 different lengths of pushrods to keep them all within Johnson's recommended pre-load range. After doing that I measure each pushrod with a caliper and match them up to each valve as close as possible.
A 1/2 turn would be .0395, A 1/4 turn would be .01975, A 1/8 turn would be .009875
So 5/8 of a turn should be .049375
So as long you are 5/8 at the end of the final torque value you are approximately 049375 of lifter preload.
When you receive your pushrods you can verify proper lifter preload using an "angle of turns" method. Set the pushrod in place and adjust lifter to zero lash. Then gently turn the rocker bolt while counting turns until the stack up of parts come together and you just begin to feel resistance to turning of the bolt. That is point where preload is set.
Any turns of bolt beyond that does not change preload, does not change the height of stack of parts. The extra turns are only stretching the threads to achieve bolt tightening torque. Those extra turns to reach torque have nothing to do with preload
The short travel lifters don't actually need that much accuracy. Main goal is to not overload the lifter. A 0.025" preload when hot is perfect (corresponds to 0.040 cold). A window of 0.038 - 0.045" preload during assembly is a good range. Johnson is being really conservative about the preload tolerance because they don't want to overload the lifters, they used to advertise wider specs with the same product. The point of all the attention to detail is to aim small so you miss small.
Pushrod checkers suck for accuracy. Use the checker tool to establish zero lash, then remove and measure the tool length with a 12" caliper. Do this for every rocker. These are not normal lifters, you need to pay attention to the details. Then call Manton and they will make further adjustments for final length of pushrod (corrections for lifter preload, engine growth at operating temperature, and geometry differences of ball end of checker tool vs. actual pushrod.) They will take those final numbers and sort into groups to decide how many different lengths of pushrods to give you and which rockers will be in which group.
Manton pushrods have a 0.003- 0.008" tolerance as manufactured at 70°F temperature and will grow or shrink by 0.015" with a 25°F temp swing. Don't freak out when the pushrods end up being a little different than nominal numbers on paper, just verify all the lengths in each grouping are reasonably correct and similar before installing in your engine. Verify preload during assembly with an "angle of turns to seat" method I described earlier.
I would also forget counting bolt turns, and guessing what torquing does (actually nothing-All torquing does is tension/stretch the bolt). All counting the bolt turns does is make more work, and possibly skew the results. When you're working with +-.010", counting bolt turns doesnt cut it. A PR checker is the only way to do this right. Che70velle made a very good suggestion on etching the PR length. I would also add that it would be a good idea to draw up a schematic/map/whatever you want to call it, listing the 16 pushrod locations and list the length for each PR at that location, and denote whether the location is intake or exhaust. Then guard it with your life!!! Like, put it in one of your old girlie foldout mags, the ones in the garage that the wife doesn't know about!!!!!
