TSP 231/237, is this a street cam
https://ls1tech.com/forums/dynamometer-results-comparisons/225097-dyno-results-tsp-231-237-patriot-5-3-stage-ii-heads.html
https://ls1tech.com/forums/dynamometer-results-comparisons/213862-absolute-5-3-heads-tsp-231-237-dyno-results.html
and there is plenty more under TSP 231/237 advanced search > dyno section
Get it!
I'm running the cam with dual crane valve springs, titanium retainers, and hardened push rods.
Running this setup through true duals dumped at the axle is about as loud as you'd want to be around town. It's loud! I had the car dyno'd when I had everything installed and tuned, but I had a bad o2 sensor, so the numbers are off.
