2002 LQ9 bonus rods!
While tearing down my 2002 LQ9 I noticed the rod ends were larger than I expected and sure enough they are GEN4 rods.
This engine came out of a 2002 Escalade. It has a Blue/red PCM and is a 6+2 DBW with a 4L60e.
I was looking specifically for a 04-07 Gen3 LQ9 ‘cause I’m gonna spray it and wanted the gen4 rods. I settled for this low mileage queen (144K on the odo) and she’s treating me right already…
Just for that I think I’ll polish her crank while I’m in here…
The following users liked this post:
G Atsma (01-25-2024)
WHOA!! Way to go!
You know what is different... cam bearings...
Looks like in 2002 the LQ9 uses the 2nd DESIGN cam bearing, that will teach me to just assume.
NOTE:
I planed on the dura bond CH-10 this is the 1st design. The dura bond second design is CH-23 (larger bore same width) BUT... everyone is out of stock and as I can tell the CH-25 is the 3rd design but is a substitute (same bore as CH-23, .145 wider) for the CH-23. Just repeating what I'm reading, I'll keep you posted.
NOTE:
NOTE:
NOTE:
I did a little chamfering/deburring on the block bores and hammered a new set in of 1st design no problem. 95% prep, 5% execution.
G Atsma (02-05-2024)
Hey thought I'd update, I was 100% WRONG when I thought I might have had 2nd design cam bearings. I dug out the old bearings and measured and they are in fact 1st design as they should be.
https://photos.app.goo.gl/jSsqDm8FzDab97ds8
it’s going slow but it’s going. I’ll toss a few pics of the car in there too.
Looks good man keep us updated! I’m doing something very similar.
question did you have the block machined or did you just do a quick cleanup on the bores(cylinder walls) with a dingle berry hone?
Just to say this…
I decided to replace the cam bearings and that meant the pistons were coming out. Since the pistons were coming out I was gonna have a look at the mains.
Both the rod and main bearings looked great but I let the magic out and I needed new rod and main bearings
So the only thing that went thru the shop was the crank to get polished.
If you really want to keep your JY build to a minimum don’t look at your cam bearings;-)
next up I’m going thru some 799 heads.
The following 2 users liked this post by epfatboy:
G Atsma (02-08-2024), JacobChevys (02-18-2024)
