Timing gear just slides onto crank... Problem?
I was working on assembling my shortblock tonight and when I got all my pistons and rods in, I grabbed my new timing chain lower gear to install it on the crank. Well, to my surprise it just slipped on without any need to press it on. It's a JP Performance billet timing set that I got from BTR. The old stock timing gear needed to be pulled off, but this one is a two piece. Separate gear and oil pump drive. My concern is without a press fit, it's going to beat the hell out of the keyway and cause it to fail. Anyone ran into this before?
The following users liked this post:
G Atsma (03-12-2024)
I know the damper and bolt bring everything together, but I don't think the bolt provides enough clamping force to keep the timing gear from oscillating back and forth due to harmonics and shearing the keyway eventually. Or maybe I'm wrong - I just don't recall a timing gear being so easy to install.
Most aftermarket timing gears slide on pretty easy. No worries here.
