Cam Motion cams.....
Hey that's that advice on the Forums that some people come here for, back in the old days and all that sappy **** that apparently doesn't exist anymore.
However, we all clearly don't know what we are talking about since we don't have a shop of precision measuring equipment to measure everything outside of the Engine unassembled with precision accuracy and throw it all together when it's go time.
This is why it's comical to me at this point. Parts failure due to worn parts and exceeding the mechanical limits of those parts, but the hardness of the Camshaft is the sole problem here.
Upper end preload numbers on the Lifters combined with most likely wore out Valve Springs, ontop of wanting to install the new ones without actually measuring correctly for their proper spec.
Yup the failure is due to not knowing the actual **** needed to know and doing things RIGHT.
But we aren't 70 years old with all this high end experience so we don't know what we are talking about. Literally me right now...
The thing is, you just don't want to hear it.
You come in here talking about how forums are for community help and advice, there's some really awesome advice in this whole post yet you're stuck in your ways on your path and won't deviate. That's the polite way of saying your head is up your ***.
You came in here posting a tore up Camshaft, several of us said investigate the problem further it's not the Cam. Eventually we've collectively narrowed it down to possibly what it is as well as some errors in your methods (you REALLY don't like that one) and now we are here.
Can't take the criticism, don't make the posts. We are here giving advice but it's falling on deaf ears.
God forbid people chime in with something other than your prefferd conversation of Cam Lobes, in that case you're guilty yourself since you've talked about other stuff. Do as I say, not as I do eh?
Let us know the next time it breaks. We'll be here.
Well, I understand your point, in my humble defense..........
The OP original problem and discussion started out with worn valve guides.
https://ls1tech.com/forums/generatio...after-fix.html
Which seems to be forgotten in the "What to blame" discussion.
I am attempting to bring the possible guide wear problem into the discussion about the cam wear, as that has been neglected in this current thread.
Below is my first of three in that above thread, the response to the above guide wear post.
Talking iron guides?
Hello,
This is the short reply,
So this my thinking, tell me if I am wrong. The chrome plating on the after market valves is too thin or soft so after the plating is worn off the stainless steel and cast iron guides gall and wear out out the guides. So the Manganese Bronze guides is necessary to prevent the galling between the stainless steel and iron guides. The OE valves must be a better quality so the chrome does not wear out.
So let me know if this correct or not.
The longer version is here
https://ls1tech.com/forums/generatio...-part-two.html
Hope that helps
__________________
So either I am guilty of bringing up irrelevant questions which should be and are ignored, or just maybe, the galling of the valves stems should be consitered in the problem of the cam wear. One would think that sticking valves would increase the opening pressure on the valve train...lifters and cam. In which the pitting would spread to the other lobes by the debris flying around.
In asking what type of guide now installed in the heads by Tony would be a clue of what a professional builder uses.
Yes, I am using Grinder's posts to get an answer about iron guides causing galling with stainless steel valve stems.
Thanks for not spanking me right off the bat!
Let me know what you think.
Damn, we forgot to keep it related to the topic..
Cam.
I'm not impressed by posting the Rockwell Hardness numbers of a Cam. I can literally do that where I work. Can take a whole Cam and test all 16 Lobes every 1/8" along them if I wanted to.
There's other things that have been proven to be the incorrect methods as well, us as the criticized community forum that are supposed to collectively offer advice and all that have chimed in, and been chastised for doing so. That's why it's entertaining. Not one of us is clearly going to change the mindset of 70yr old hard headed fool so we will sit back and watch when something else blows up because they "think" they know the method and don't want to pay attention to actual specs things need to be built to. Just the truth of what happened here. Truth hurts nowadays. Deal with it.
Not my money, not my car, not my problem. Carry on and blow the **** out of it, full send. Impress us.
I'm not impressed by posting the Rockwell Harness numbers of a Cam. I can literally do that where I work. Can take a whole Cam and test all 16 Lobes every 1/8" along them if I wanted to.
Regarding the pushrod measuring deal…if the heel of the new cam measures the same as the old cam, the math is super simple to figure for new cam regarding pushrods. Don’t worry…Mike is a trooper and WILL measure for new pushrods regardless…he’s simply using an old trick we use to get in the ballpark for pushrods. You guys jumped all over him about this..I was rolling…I guess it’s an old method that some of you guys haven’t used before.
Doesn’t really matter if your impressed about the Rockwell hardness testing or not. It’s legit and it’s actual TECH….very seldom on here do we see actual tech. Bravo Mike for testing this stuff, both cam hardness AND springs. That’s going WAAAAAAY farther than anyone here lately.
Mike never chastised anyone here. I don’t follow what your getting at. In fact…you did most of the chastising here. A couple others jumped in because it’s an Internet forum and that’s simply what humans do. They look smart behind a keyboard…ok.
FWIW, Mike is a recently retired tool and die guy who can use instruments with his eyes closed. I’ve talked with him one the phone a few times over the last couple years and he’s a really smart guy, WHOS STILL WRENCHING ON A C5 CORVETTE. You own a C5, so you can relate to this. It’s a chore to tear the front off of those engines. He’s still at it at 70. I tip my hat to him for that. He doesn’t have a lift either, so that’s bonus points for him right there. I’ve got a lift and I HATE digging in to my C5. I’m about to pull the rear cradle/torque tube out of my C5Z for the 3rd time…and I have a lift. Still sucks.
Mike knows and COMPLETELY understands specs things are supposed to be built to. He put an LS7 in that car along with Gen4 electronics and made the swap work flawlessly for the last several years. Mike would…AND SHOULD HAVE SPOKEN UP FIR HIMSELF…but he’s not that type of guy. He just laughs at all the antics here. Very thick skin, he has. Must be a 70 year old deal….anyhoo…carry on.
When you're referring to work hardening, are you talking about during the grinding process? Machining can increase hardness if done improperly, but in correct practice shouldn't. As far as the use goes, there's not enough heat and pressure to add any significant hardness (especially if the valvetrain was setup properly).
I don't recall if all the other responses in detail. But I believe intended messages regardless of the delivery are centered around a couple key points:
- There are a ton of critical factors involved that can influence premature wear in the case of a valvetrain.
- Failure of the part, doesn't necessarily mean the part itself is incorrectly designed or defective. Often people make the connection that way, but it can be incorrect more often than not, especially as you add factors of a system.
Anyway I wish you well in your build. And I hope you do find your root cause whether it's the cam itself, the valvetrain setup, or another defective component causing the cam to go bad.
Odd that I was insulted for asking these questions like what was the lifter preload and how did you measure it? Those seem like legit questions to ask when there is a valve train failure no? When I ask those things I'm compared to a 5 year old because he doesn't want to be asked about details because it might be discovered that he had previous valve guide failure through no fault of his, but it did happen and might be discovered he was running lifter preload 50 thousandths beyond the upper spec limit of the lifters.
Instead of dismissing anyone who asked questions specific to the engine build and valve train setup and comparing them to 5 year olds he could have simply stated I did have a previous valve guide failure on my ls7 heads, but I don't believe that impacted the cam. Right or wrong that would be a better answer than attacking anyone who questioned him. When asked if lifter preload was checked and what preload was he running he could of simply stated how he checked and that when he switched from ls7 lifters to johnson lifters he had the lifters measured on precision equipment to make sure the same pushrod length would result in the same lifter preload for both lifters. This is probably satisfactory if you ignore the fact that ls7 lifters and johnson lifters require different preload. Instead he attacked anyone that questioned him.
The facts are he started multiple threads on the same topic which is a red flag in my opinion. Then would not answer questions about the build and attacked those that would question him. Some things were eventually answered and then showed some incorrect specs were used. The valve guide issue was never disclosed by the op and was only known because another member remembered that thread. Most of us know nothing about the op's engine combo so these types of questions seemed very reasonable to me, but we were attacked and compared to children for asking these types of questions. No one really said the op was at fault just asked questions about specifics of the build. After some of those facts did come out then that is when a few members started getting sarcastic. They got sarcastic because their questions were dismissed and they were compared to children how dare anyone ask the op any questions and when they did the OP immediately started making claims that his credentials were better than anyone else here how dare you question me...LOL.
Yep the rest of us caused this and the OP couldn't have done anything different to not send his multiple threads in an ugly direction...LOL
