LS1 - Pre Install (drift engine)
Old Oct 9, 2024 | 08:23 AM
JCabr's Avatar
Default LS1 - Pre Install (drift engine)
Hey guys,
My LS1 finally went, and I'm grabbing another used alum 5.7 with 241 heads to replace it with.
What should I do prior to install to keep the engine happy? It's strictly used for drifting with very low street miles in between events.
I was thinking lifters, trays, head gaskets (obviously) and oil pump. Anything else?
What type of lifters, oil pump will keep this thing going / happy for a while?
Old Oct 9, 2024 | 10:53 AM
Don't forget the cam retainer plate. They do wear.
Old Oct 11, 2024 | 09:42 AM
JCabr's Avatar
Will do, thank you!
Old Oct 11, 2024 | 10:17 AM
Kjduvall's Avatar
id do pan gasket,front and rear main seals too.
Old Oct 11, 2024 | 10:56 AM
Originally Posted by Kjduvall
I'd do pan gasket, front and rear main seals too.
Good call since the engine's out.
Old Oct 12, 2024 | 11:01 AM
wannafbody's Avatar
I'd pull the heads and upgrade lifters and replace the trays with Genuine GM parts. Easier now than later.
Old Oct 12, 2024 | 12:43 PM
He did mention those and head gaskets. Looks like he has it covered.
Old Oct 12, 2024 | 07:42 PM
DualQuadDave's Avatar
Valve springs and a Katech C5R timing chain, for sure.
Old Oct 13, 2024 | 08:49 AM
New headbolts…
