Blower LM7 build Questions
Long time reader, first time poster, lol. I am building a LS3/LM7 2007 5.3 engine and looking to put a 6-71 roots style blower (old school) on this engine. Question is, would it be cheaper to piece meal the blower system or just buy as a kit? Another question is, I'm looking for a hir-rise manifold as well, that's why I thought about buying the blower in pieces and not a kit.
Anybody have a shop they like to recommend on buying most of this stuff?
go do some research
To keep it simple I'd just go with a kit.
https://www.motortrend.com/how-to/17...dern-ls-engine
https://www.speedmaster79.com/Chevy-...MM2KkwR8&gQT=2
https://en.wikipedia.org/wiki/Genera...l-block_engine
If I am way off base then, please tell me what I have? I am all ears.
Thanks 01CamaroSSTx, I have seen those sites and although Speedmasters setup is exactly what I want, I am also looking for a hi-rise manifold. Most kits I have seen don't have one. I am not doing EFI so I don't need the rails.Besides, Speedmaster shorted me a crank stud nut and won't return any of my emails. LOL
Yes, it is a block I have cleaned up and bored and running stock heads which are the exact heads that were on it.
This will not be a drag car but just an old school show truck. I don't plan on doing more than 8 psi of boost, if that.
That speedmaster blower kit still work, correct?
LS1, LS2, LS6, and some others all came with cathedral port heads but some engines came with a larger bore such as the LS2, LQ4 and the LQ9 which came with 4.00 inch bore. The LS3 came with a 4.065 inch bore and came with rectangular port heads which were 821 castings. The LS7 was the largest displacement LS engine that had a 4.125 in bore and used LS7 cylinder heads which haveba 12° valve angle where the other LS engines came with a 15° valve angle. Not sure but I'm sure the balancer will be fine.
I found this on google in 10 seconds to learn more about LS engine family.
https://www.google.com/search?q=ls+e...hrome&ie=UTF-8
That blower will look cool.... but it is a heat soaker and definitely not very efficient. SpeedMaster is total China derived stuff so beware.
heads cleaned, new springs, decked and magged, new valve springs 120+ closed 295+ open
block cleaned and 3.785 bore
New forged pistons, piston rods, rings gapped to 0023, bottom 0025
new cammotion cam
2126LSR slow leak down race style lifters with axle oiling
Stock crank (cleaned)
Still looking to get push rods
If you have a different site to buy the blower kit I would rather do that. I am aware they are mostly in china, I can't get them to return any emails about their products.
Here's one from alkydigger - https://www.alkydigger.net/product/TBS2219.html - I'll need to contact them as it doesn't specify what manifold it is.
I recommend AlkyDigger.
I didn't buy one of their kits, but they helped me out a lot on parts. This is a 6.0 LQ4 with the LS6 heads. The lower manifold was an LS3 style manifold, so it has the square port -> cathedral port adapter on it. I sold it about a year ago and it's still out there, the next guy swapped out the mechanical fuel injection for a dual carb setup, but the blower setup is the same.
The part number 12567392 refers to a GMC and Chevrolet 5.3L LS Gen III V8 OHV short block, specifically the LM7 engine. This iron-block engine was commonly used in GM trucks between 1999 and 2007. The LM7 is also sometimes referred to as the "Vortec 5300"
So it appears I did do my research, I accept your apology
I took Gen III as an LS3, so my badI will more than likely buy the alkydigger Blower, been talking to them. So thanks Onbusy
