LS1 Piston rings
Old Sep 6, 2025 | 11:12 PM
Its38's Avatar
Default LS1 Piston rings
Ive got an LS1 that's bored 0.030 over and I have pistons to match, but I can't find piston rings anywhere that will fit the overbore.
the pistons are from speed performance (PN: H868CP0.75MM) I checked there website and can't find a solid number to call and can't find the supposed piston rings they sell either. I plan on calling summit Monday to see what all they can help me with because that's where the so called pistons and rods were bought.
EDIT: I found some Hastings Piston rings that fit the piston and is the bore I need, but its the only set of piston rings I see online.
TLDR I need 0.030 over piston rings what all have you guys ran if you've bored it over?
Old Sep 6, 2025 | 11:42 PM
IF it's an actual aluminum Gen III LS1 it should NEVER be bored .030 over. Walls will be too thin.
Old Sep 7, 2025 | 02:06 PM
Utinator's Avatar
You are going to have a hard time finding someone that has done this before. I have never heard of an LS1 being bored that far over. Typically, .007" is the max. That's why you won't find off the shelf pistons bigger than a 3.905".
Old Sep 7, 2025 | 05:52 PM
grinder11's Avatar
Agree with the rest; .030" oversize bore is a unicorn with a mermaid mother. If it is actually bored .030" over, I'll bet some patches of aluminum may be visible in some bores. It would be a very interesting discussion with the guy that bored it!!...
Old Sep 7, 2025 | 10:54 PM
01CamaroSSTx's Avatar
.030 overbore was the first thing that jumped out at me too. Are you sure that your talking about the LS1 block? Perhaps you meant to say .003. I haven't seen a 3.901 LS piston but I'm betting they're out there.
Old Sep 7, 2025 | 11:08 PM
Its38's Avatar
That's what I told when I bought it, Ive got pistons that are 0.75mm bigger and it 0.75mm in inches is around 0.029/0.030
block that's been bored over
Pisonts in question
Pisonts in question
Old Sep 8, 2025 | 09:36 AM
Utinator's Avatar
I would like to see a caliper across the top of the cylinder, measuring the bore. It's more likely to be .003", not .030" over.
Old Sep 8, 2025 | 09:56 AM
Its38's Avatar
once I can get a gauge and measuring tool I will post what it shows... I fit the pistons in which are 0.75mm oversize and they fit so I would assume it really is 0.030 over
Old Sep 8, 2025 | 11:46 AM
slowride's Avatar
They do make pistons that big as replacements that are sold in .12mm, .25mm, .50mm etc etc, but the machine shop needs to know better that it will not work. I take it they don't work on many LS? That block is now a paperweight.
Old Sep 8, 2025 | 02:11 PM
Like I said....
Heed and believe, Its38....
Old Sep 8, 2025 | 02:55 PM
Tommy42088's Avatar
Maybe thats why the guy sold it?
Old Sep 8, 2025 | 09:36 PM
I'd be curious to know what those bores measure out to be as it looks to still have quite a bit of sleeve there. Have you measured to see if those pistons will go into the bore?
Old Sep 8, 2025 | 10:07 PM
I’d guess it’s an L33? LS1 can go .005” safely, as we all know.
Old Sep 8, 2025 | 10:25 PM
1FastBrick's Avatar
I found these on Summit Racing for a 3.927 Bore. 1.5, 1.5, 3.0 ring pack. These will work if those pistons fit that block and everything checks out
Hastings Piston Ring Sets 2M5097010
Old Sep 9, 2025 | 08:24 AM
Keith's Avatar
What is the casting number of the block? That should let you know if it's a paperweight, or it's a bored over L33.
Old Sep 9, 2025 | 10:07 AM
slowride's Avatar
I don't think the sleeve OD of a L33 is any different than a ls1 honestly on gen 3 stuff. I highly doubt GM had a sleeve that was a different OD based on extra parts/tooling. Back in the day it was common to open up a L33 to LS1 size sure, but not 0.030"-0.040" past that also.
Old Sep 9, 2025 | 09:36 PM
Lots of L33’s out there at .030 over. Gen3 and Gen4 5.3 aluminum block liners can go .040 all day. I’d bet $10 this block is an L33.
Old Sep 9, 2025 | 10:04 PM
the_merv's Avatar
Veteran: Air Force
I found a set, don't know who chanced a LS1 to go .030" over but there are Pistons out there for it.
https://www.jegs.com/i/Sealed-Power/...P75MM/10002/-1
Take it for what it's worth.
Old Sep 10, 2025 | 11:03 AM
Its38's Avatar
I don't have the casting number wrote down anywhere easy for me to send, BUT I have looked it up it shows as an LS1 and the guy I bought it off of said it was out of a 2002 Firebird.
I have fit the pistons into the block on to a crank without rings and they tap in just fine, personally I don't know what to thin piston walls would look like but they look fine on my end.
Old Sep 10, 2025 | 12:02 PM
Tommy42088's Avatar
how did you look it up if you dont have the casting numbers? You may want to listen to these guys before you spend money putting an engine together and tearing something up. Trust me I've been down a long road with my truck and every single part I put on my truck that I was told not to use i ended up taking back off and replacing. Ive spend double the money building my truck because of it.
