My Oil Pressure Sucks
At idle the the pressure isn't constant, but the RPM's are; it kinda flickers around. And before the cam, it was a little less than 40 at idle, no matter how hot the car was.I'm seriously thinking it's just a pinched o-ring and not a bearing. Well actaully I'm hoping, praying and everything else that it's not a bearing. I was thinking if it was a bearing, it would only lose pressure to that single bearing, and not the entire engine. Am I correct?
I'm gonna tear it apart in the next few days and replace the o-ring, hoping it helps. Any other ideas??????????? Or any tips on getting the pickup tube bolted to the oil pump faster without pinching the o-ring?
Thanks
Ryan
-Sly
Seriously, invest the $150 in a ported oil pump, you won't be sorry.
-Sly
-Sly
Speed Demon didn't want to dyno tune my car b/c he had a customer throw a rod through the block w/ the same oil pressure. I'd rather be safe than sorry.
-Sly
-Sly
