any1 swap motors themselves on jack stands??
i have a 2000 vette. how much of a biatch is it to swap the old block with a new forged shortblock on jackstands? and how the hell do u realine the driveshaft to the pilot bearing when u reinstall the motor?? of course id be doing the swap alone
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Originally Posted by pdd
seems like the hardest part would be lining up the pilot bearing with the driveshaft when reinstalling the motor. they have to line up perfect ![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
6600 rpm clutch dump of death Administrator
I haven't done it, but I would really consider droping the torque tube shaft and re-installing it after the motor is in. I think your swap would go much easier.
Originally Posted by ls1290
I did my C5 swap with jack stands by pulling the motor from the top. Just had to remove the hood. Other than that, no major problems or hang ups.
Would this be easier than doing a heads/cam/clutch swap with the motor in the car?
Can you give us C5 owners any tips? Can you disconnect the ECU harness and pull it through the firewall, so you pull the harness with the engine? I've seen this done on some cars.
Or do you have to disconnect the harness from the engine? This can be a PITA.
I've done 4 in f-bodies and we just jack it way up and drop the k-member with tranny attached. I am not familar with the corvette driveline so I can't comment on that. Definitely need at least one extra guy when reinstalling to help line things up.
6 Second Club Moderator
Originally Posted by thtdmbdss
Is a camaro easier from the bottom or can it be done from the top?
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
