Machining for 382 stroker
Old Oct 21, 2004 | 11:02 AM
1BADAIR's Avatar
Default Machining for 382 stroker
Does the block need to be notch or anything for a 382 stroke? Also which cam do you guys recommend. I was thinking some where in the high 230's.
Old Oct 21, 2004 | 11:04 AM
LOnSLO's Avatar
No notching necessary on the block for a 4.00" stroke. You may have to shim your windage tray a little though.
Old Oct 21, 2004 | 12:16 PM
SAM98WS6's Avatar
You will need to notch your block depending on what rods you use. Callies=yes. Rod bolt heads (ARP) hit. Plus you will need to notch a piston for reluctor wheel clearnance if it isnt already done. Just put it together and spin it by hand...I had mine apart 5 times until I thought it was safe...used an air grinder for clearancing.
Core shift is an issue in LS1 blocks...might only hit on one side and not the other.
Mine is 242/250..wouldnt go any less...
Old Oct 21, 2004 | 01:22 PM
Camaroholic's Avatar
I had to notch all 8 cylinders for the L19 bolts in my Eagle rods (no big deal, air grinder here too). Even though my Ross pistons were "pre-notched" for the reluctor wheel, I still had to do a little additional grinding on #8 to clear, and very slightly on a couple of the other pistons (to clear the bobs on the crank). Also had to notch the oil pan, and space the windage tray. As for cam, a solid over 260 works great too.
Old Oct 21, 2004 | 05:23 PM
strokedls1's Avatar
Had to do a little clearance with an air grinder on the bottom of ever cylinder with 4" stroke callies and eagle rods with upgraded arp bolts. I just use the washers that come with the arp main stud kit to space the windage tray a little. Had the crank together and apart a couple times to check clearance before a final cleaning and assembly. If idle isn't a big concern I would go mid-low 240's.
Old Oct 21, 2004 | 06:15 PM
SSPerformance's Avatar
reluctor wheel clearnance ????
Old Oct 21, 2004 | 06:34 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
That's clearance for the crank trigger. The crank trigger is located right below the the number 8 piston when installed. On large strokes if you do not check this you could end up crashing the piston into the trigger wheel. That would lead to some serious piston damage.
Old Oct 21, 2004 | 06:41 PM
you have to notch the bottom of the piston??
Old Oct 22, 2004 | 08:55 AM
LOnSLO's Avatar
Yes. It may take a couple of times to get it right.
I've never had to notch the block for a 4" stroke, but I've also never used Eagle rods with the L19 bolts.
Old Oct 25, 2004 | 11:10 AM
1BADAIR's Avatar
How is the drivabilty on the street? Any sound clips?
I am thinking about a 238 242 609 612 112 or a 242 242
Old Oct 25, 2004 | 01:05 PM
SAM98WS6's Avatar
No sound clips but it sounds pro street Everyone loves it.
I drive it every day its nice. Loads up a little sitting in traffic for some time...then you have to blow it out. Go at least that much...
Old Oct 25, 2004 | 01:11 PM
1BADAIR's Avatar
where does it make power? How high do you rev it? Have you had it dyno'ed
Is this what you have-SS3 242 250 .611 .619 114
Old Oct 25, 2004 | 02:13 PM
SAM98WS6's Avatar
do a search in the dyno section for my curve
242/250 .595/.595 (1.75rockers) 109
Remember I only have 2.02 LS1 66cc heads....not ls6
