Wheres everyone getting fresh stock shortblocks from?
Originally Posted by Jason99T/A
I can build you one if you want. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
LS1TECH Sponsor
Completely stock shorts are $1500. Add a JE Piston and Ring Set, ARP Main Studs and Rod Bolts and I can do them for $2400. All blocks are cleaned, inspected, line honed, square decked, honed with torque plate (warm), rods re-sized, crank polished, rotating assembly balanced and new cam GM bearings installed. We use either GM or FM bearings. An engine build sheet is included with every block.
These are rotating assemblies only. No cam, lifters, chain or pump.
