New cam is in, but very very loud clicking
Ok I am used to noisy valvetrain, I have had heads and cam with full exhaust forever... so trust me its not that Im not used to it. I just did a cam swap for a larger cam and fired it up. Loud clacking from the front, I let it go for 1-2 minutes since it built oil pressure and was idling fine. However the very loud ticking did not go away. I am guessing that I the rocker arms are torqued down way too tight. I read on here somehwhere that no matter how hard u tighten the rocker bolts it will not affect the valvetrain geometry and will not cause any adverse reactions. Should I let the car run longer than 2 minutes? or Should i take the valve covers back off and verify the torque specs on all the bolts. I know they are not too loose, if anything they are way tight. Let me know your thoughts on this
Did you use a torque wrench on the rockers? I ask because you already feel it's way overtight. Did you measure ptov? I'm asking because it's possible the cam is too big.
All things you know already, just asking the obvious.
Myself I'd take off the valve covers and at least look BEFORE trying to run it longer than 2 minutes.
http://www.ls1howto.com/index.php?ar...6ddae7036e5d9e
I always understood it at 22 ft/lb's for rocker arms. When we did mine,( 225/225 .589/.589 112lsa) we rotated the crank/cam untill the pushrod was off of the lobe of the cam. That's when we torqued each rocker arm down. It could be a bad rocker arm also. Have you ever changed the lifters?
Lifters are fine, I understand it is 22lb/ft however I was put in a position today where I didnt have a torque wrench and winged it. I felt comfortable doing this due to the fact that I was told the stock rocker arms will only tighen to a certain point and after that you are only tightening the bolt itself therefor causing no change at all. Maybe this is all wrong though
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
https://ls1tech.com/forums/generation-iii-internal-engine/243444-how-fix-collapesed-lifters.html
I know that the title of this post is BAD LIFTERS, but there's some pretty good posts explaining why the torque specs are important. I'd look into backing up and torquing them down correctly. I'm not an expert, but you just may not be giving the rocker arms any "Play" by torquing them down as hard as you can. Good luck, on the fix.
Originally Posted by Another_User
What are the cam specs?
did you mess with the oil pump at all. I did a cam swap and my car was ticking and clicking like crazy. I thought it was a rocker also but it turned out being the o-ring in the oil pickup tube. if you do a search you will find a very long post about it.
Originally Posted by flippincamaro
is it piston to valve contact not sure but that was my problem cause of the timing. mine was a loud clacking noise aswell sounded like a diesel good luck
Cam: 236/239 .600/.611 111
Currently have 978's installed as springs but was going to switch to PRC duals before ran it hard.
I have notched pistons and I verified with Allan at Futral that P to V clearance would be fine with my heads. Also turned the motor over by hand before reassembly and heard no warning signs.
Oil pump is good to the best of my knowledge, had 60 psi cold and 40 psi warm holding steady. Actually better oil pressure than i had before.
Will pull V covers in the morning and go from there i guess
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
Originally Posted by LS1UltraZ
Update: I let it idle for about 5-10 minutes, sound did not lessen at all and right before i was cutting it off a hear a loud POP from the engine compartment. I promptly turned it off and headed back up here to post. The pop did not travel through the exhaust so im ruling out backfire... it sounded mechanical and it sounded BAD.
Will pull V covers in the morning and go from there i guess![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
Also, are you sure you got the cam timed right? If I am not mistaken, that is critical with a cam like that.
I had a feeling you were going to say over .6xx lift. I'd say that is a piston to valve clearance issue. Have your heads been milled?
The timing is right on, dot to dot the whole way. HMMMMMMM
![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
Guys, my buddy is comin over... we are pullin an all nighter tryin to find out what is wrong. Even uncle Jaeger is comin to the party lol. Let me know what else I should check, and ill be posting up with progress. Its 9:30pm, let the fun begin!
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Looks like you did the right thing,tighten things untill they start to get loose again.I'm with you on bad noises,run the motor till it makes a louder noise and it makes it easy to find.
I disagree with Futral. I am anxious to hear what you find. I heard dot-to-dot isn't always accurate. I put my cam in, and dot-to-dot is really hard to do. You could easily be a tooth off.
OK guys found the problem. Pulled the valve covers and guess what every single rocker bolt was loose. This is amazing to me since these things were OVER torqued. I guess I have learned today that if overtorqued to the extreme they will be forced to work themselves loose lol. Anyways, torqued them all to 22 lb/ft WITH a nice torque wrench threw it all back together and it purrs like a kitten.... well besides the large loping cam noise
Then i look under the car.. and guess what oil is steadily dripping out of the crank pulley area. Looks as if I didnt get the crank pulley all the way flush and back and oil is coming out. I am trying everything I can to push that pulley all the way back but its not workin. Im going to try and put some large washers on the crank bolt and screw it in since I think the stock bolt is bottoming out and still not pulling the pulley on. Any tricks you guys can share?
Sean
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Sean
Stock pulley or ASP? The ASP shows some machined surface and looks like it should slide on a bit more but it's all the way on as long as the belts line up. I'd check the seal...
