Katech Vs. ARP Rod Bolts?
Katech's Rod Bolt is about the same weight and length as the stockers with good tensile strength. This will do less to throw off the how everything is balanced right? It will also keep from deforming the rod ends if i read everything right.
ARP bolts are heavier and longer helping to unbalance rotating assembly some. So besides price, why do more people go with ARP Rod Bolts over Katechs (besides price)?
Seems if you want to spin the motor to higher rev's you wouldnt want to do something that would throw the balance off, even if it is very little. Just a newb trying to learn, so educate me guys
BTW, I now have about 490crank hp and 470crank torque. I have made several trips to 6800rpm and one to 7200 when I missed a shift and no issues.
TOTALLY AGREED HERE!! My dad is an engineer and im going to be in the same field he is in (I'm at college now) and he has taught me to just wait it out and look at everything even if it sets you back a while it would almost all the time be worth the wait to get everything done right the first time.
I would take ARP hands down. Resizing a rod is a neccessary step in thsi process IMO. If you are willing to skip that step you might as well skip the new bolts and pray that the stockers will hold (they won't)
Just a little info on the Katech rod bolts, they aren't made directly by Katech. They are made for Katech by A-1 technology's in California. They are a large fastener company that was hired by GM to make the ASA rod bolts. After GM did all of the testing on them, with the help of Katech, Katech then became the source to purchase these bolts from. A-1 also makes mutiple other fasteners for GM, including the studs that come with the C5R blocks.
Thanks
If I remember Screw to Win correctly, a bolt's strain (stretch) as its tightened is what applies a force holding the head against the rod which holds everything together. Seems like this wouldn't necissarly mean you need more torque with a stronger bolt, maybe just less strain. But I dunno, I'm no ME....
Never reached stretch dim before they snapped. More than one set up also.
ARP hardware in far from perfect and has it's "issues". They just spend more money in advertising so they are more familiar to the masses.
Ed
Clamping abaility is the determining factor. Not the torque value. Besides, you should be setting your rod bolts up with stretch not torque values.
