HP/TQ diff between LS6/5.3 heads??
would I see between a LS6 stlye LQ9 casting and a 5.3 casting.
Assuming both heads have Stage ll work, same 205/160 valves,
same 59cc chambers?? Any other advantages/disadvantages of
either of these heads?
Thanks!
now the ls6 style are ~1400 bucks
FWIW a set of PP ls6 style heads that i had a chance to have independently flowed and spec'd out flowed my TEA/FFHP by a good margin from .400 and up. my 5.7's are similar to the PP 5.3's. take that for what its worth...
oh yea, same bench, operator, and conditions.
i've always liked TEA/FFHP's work, heard nothing but great things about them. Hard to beat PP's "LS6" stg2's for ~$1300 out the door tho, especially since they revamped 'em. Definitely great bang for the buck.
2.02/1.57 valves
224.5 int / 83.7 exh port volumes
3 angle valve job
milled .020
the CNC'ing was done by TEA and FFHP did some hand finishing and final assembly. the heads were not refreshed, started from a clean slate with a new 241 casting. i had my cam spec'd to the air flow and it cam out to 238/236 duration if that tells you anything
