Do FMS cams use XE or XER lobes?
Old 01-27-2005, 11:22 AM
Bad Blu Formula's Avatar
Default Do FMS cams use XE or XER lobes?
Also, what would be the better type for a daily driver that only sees the track every couple of months?
Old 01-27-2005, 11:27 AM
jrp
SN95 Director
jrp's Avatar
neither, they use cam motion.
Old 01-27-2005, 11:58 AM
01_SuperSlow's Avatar
They use cam motion lobes, which are supposed to be softer than comp xe-r lobes.
Old 01-27-2005, 12:11 PM
stevensLS1's Avatar
not to jack the thread but whats the differnce between the 2 lobes?
Old 01-27-2005, 12:26 PM
jrp
SN95 Director
jrp's Avatar
it goes like this:
XE < TR lobes & cam motion < XE-R
Old 01-27-2005, 12:27 PM
BLASTER's Avatar
Camotion have faster ramp rates...meaning that they are steeper than the comp lobes. Assuming equal lift and duration...imaging a more egg shaped lobe compared to half circle lobe and that is the physical difference.
Old 01-27-2005, 02:37 PM
Unaffliated Racing's Avatar
More than 1 of these posts are incorrect. I can't tell you which ones and why...sorry.
Old 01-27-2005, 02:58 PM
Futral's Avatar
The lobes we use are not as aggressive as a XE-R series lobe. The are very close to the LS1 HIGH RPM series. So of the lobes we use from Cam Motion our own design and some of their lobes. Our cams use lobes that are the best overall for power,idle,drivability and stress on the valvetrain.
So they are not Comp lobes.
Old 01-27-2005, 03:12 PM
LS1_PNYTAMR's Avatar
how long can u go on the f13 without changing ur say manley or prc dual springs then?
i assume longer then u could with a similar spec'd xe-r grind right?
Old 01-27-2005, 03:15 PM
not to jack this thread.. but are the lobes the reason they dont seem to lope very hard.. ive heard a f13 112 lsa cam next to a 228/232 113lsa cam, soundclip, and various others... the f13 sounds closer to a tr224, is this becuase like jrp said the ramp rates or whatever are about the same?
Old 01-27-2005, 04:06 PM
AINT SKEERED's Avatar
your right, mine does not lope to hard for the size cam I run.
Old 01-27-2005, 04:19 PM
BLASTER's Avatar
mine either...it's stock i'm already thinking of my next FMS cam, LOL
Old 01-27-2005, 04:30 PM
Not me, mine is staying for a while. L O L. It is a good all around cam, and I have not seen every thing that it has to offer yet
Old 01-27-2005, 06:38 PM
Beast96Z's Avatar
"Lope" is a derivative of duration and overlap. FMS cams may not have as much overlap as the other cams you listened to. The lobe type is only going to make your valvetrain louder, the harder the lobe. It should have no or minimal effects on "lope".
Old 01-28-2005, 05:55 AM
02Reaper's Avatar
I may be wrong on this but from what I have heard, if you take the .006 specs of a cam and subtract the .050 specs, then that will tell you how aggressive the cam is. If you do that to my cammotion cam then, you end up with 50. Comp xer cams start at 48 and go down. Comp xe and High rpm series are all 53 from what is listed on the web page. It would appear to me that the Cammotion cams and the TR cams are closer to the XE-R , aggressiveness wise. That is four points less that the XE and XE High rpm, and one point away from the XE-R. Maybe someone can clear this up if I am wrong.
Old 01-28-2005, 06:51 AM
DAPSUPRSLO's Avatar
This is called lobe intensity and you are correct. You can also subtract the .050" number from the .200" number as well.
Old 01-28-2005, 08:38 AM
dug
dug's Avatar
Has anyone cloned the FMS cam specs using x-er lobes?
Old 01-28-2005, 10:28 AM
Beast96Z's Avatar
All the XE cams are 53 diffrence between advetised and .050. The XE-R's are all 49. The Futral and TR cams should all be about 50-51.
