Typical Conditions of Blowing the Bottom End?
The engines don't "shell" per-se, depends on how quickly you catch it. All of us caught our cars quick enough that it was only necessary to change the crank, one rod and bolts (it can get a lot worse though)......but none of us did just the minimal
Now understand, in road racing one is mataining high RPM's for prolonged periods of time and high G turns can also cause oil starvation, in a 1/4 mile you're only seeing those RPM's for a very shot time (no oiling issues). That being said, in keeping your RPM's down, I agree with the above post of get the money in the bank but it should hold - for a while
TheBowtieboy,
How high were those cars being reved? 6200 is pretty damn low... I guess I'll lower my rev limit on the road course, sigh.
I disagree. The tension on the bolts is directly proportional to the square of the crank speed and the weight of the piston/rod assembly. Greater power could mean a greater variance in the speed of the crank over each 720 degrees of rotation, which of course could cause a variance in the tension on the rod bolts. But that doesn't really sound significant, does it?
I think the rod bolts are loaded the most when they are pulling the piston down during overlap. If they are going to fail, I believe thats when it happens.
IMO. I just don't see how greater amounts of cylinder pressure could put significantly more tension on the rod bolts.
