Do heads or not?
Old Mar 4, 2005 | 01:36 AM
Mike00FRC's Avatar
Default Do heads or not?
Here's the deal. Current mods are in the sig, but I have the following, waiting to go in: FMS F-14 232/234 .598/.598 112, PRC Spring Kit, LS6 Oil Pump, LS2 Timing Chain, and a few other smaller items.
Problem is that I have about a grand just burning a hole in my pocket. Do I throw in a set of 3.90/4.10 gears now, or scrape up another grand and do heads at the same time I do the cam? Modding-wise, I should probably do the gears first, but it would also make sense to do the heads at the same time as the cam... already looked into getting a bare set with valves as I have the rest.
Any opinions?
Mike
Old Mar 4, 2005 | 02:14 AM
8banger's Avatar
Go heads...your car is an M6 so you can kind of make up for the lack of gearing for the time being.
Old Mar 4, 2005 | 08:12 AM
GuitsBoy's Avatar
Dont buy gears for a 10 bolt with your mods, youll have to buy a 12 bolt soon enough anyway. Choose your ratio then. Id say get the heads... your car may dog a little down low, but you should really look into a 12 bolt as soon as possible.
Old Mar 4, 2005 | 08:17 AM
SAM98WS6's Avatar
Hey Mike...Hows it going?
You still at it?
Old Mar 4, 2005 | 08:20 AM
Raise's Avatar
heads all the way!! u will thank yourself for doing the heads at the same time as the cam. the cam swap is much more fun with the heads off.....a lot easier too u wont have to worry about lifters fallin. plus, the heads and cam will compliment each other a lot more than the cam with your stock heads. i say get all your valvetrain knocked out in one install. then just take it easy on your drivetrain til u have money to upgrade it.
Old Mar 4, 2005 | 08:51 AM
Race Car Driver's Avatar
11 & 7 Second Clubs
Any opinions?
Mike
Heads are the key to making power, so I recommend purchasing a good set.
Old Mar 4, 2005 | 09:11 AM
CCSRACER's Avatar
I say scrape up another 1k or so and buy a 12 bolt w/4.10's and put on nice sticky tires.
Old Mar 4, 2005 | 02:58 PM
SAM98WS6's Avatar
I have your old ARE heads if you know anyone who wants a real cheap set..they just need springs...had them all cleaned up...
Old Mar 4, 2005 | 03:02 PM
Fulton 1's Avatar
Originally Posted by CCSRACER
...buy a 12 bolt w/4.10's and put on nice sticky tires.
Its a 2000 FRC.
Old Mar 4, 2005 | 03:39 PM
LS1_PNYTAMR's Avatar
Any opinions?
Mike
ill be putting in the same cam/springs/chain/pump about the same week as you lol.. im putting in a gear with it cause i have stock 3.23's now, but if i could afford like some bare patriot heads or something cheaper like that i would prolly go ahead and do it, even tho my dream set would be afr's. i may do some mild port work to my stock heads, dont count this idea out.. cheap and fairly simple ive been told... maybe this will hold me over till i get some afr's and a fast 90.
Old Mar 4, 2005 | 03:41 PM
may i ask why u went 112lsa over 114.. alan stressed to me the importance of 114lsa with my 150 shot on a cam this size when i ordered.
Old Mar 4, 2005 | 05:25 PM
Mike00FRC's Avatar
Thanks guys... looks like it will be heads.
Sam,
Good to hear from you. Thanks for the offer on the heads, but the cams a little big for the 2.055 valve and shaved 30. I see you've got the T/A running pretty good. I was pretty much out of the loop for a while, but trying to get back in. I sure I'll run into you somewhere this spring/summer.
LS1_Pnytamr,
I went with the 112, as I have an M6 and was looking for a bit more lope and slightly lower peak rpm. Also, I'm not running that big of a shot, so N02 compatability was not a deciding factor. Plus from my understanding anything under 150 doesnt make much of a difference.
Mike
Old Mar 5, 2005 | 03:56 PM
M6HuggerSS's Avatar
GET SOME HEADS!!!! youll be glad you did.
