Advertised stock cam duration for 02 Z28?
I am trying to pick out a torque converter and the one I am considering specifies an advertised cam duration between 265 degrees and 280 degrees and I was wondering what the advertised cam duration for a stock 2002 Z28 is.
Can anyone help me please??!!
Thanks!!!!!!!!!!!!!!!!
That's what she said...
check out the stickies at the top of this thread, a guy who posts as JRP has a bunch of info in his sig with the specifics of every year f-body. cam, fuel injectors, etc.
a 3000+ stall works very well in these cars, more or less depending on how much you want to go to the track and what tires you're running.
BTW - everyone talks about durations measured at .050 around these boards.
SN95 Director
https://ls1tech.com/forums/showthrea...hlight=cam+pro
theres the data from my 98, i'd imagine the 01-02's would be the same, if not within a degree or two.
I have no advertised figures for zero or .004 cam lift, these are at .050 cam lift for 2002 Z/28.
{I/E duration} 196/207 @.050, 116 lsa, .467/.479 lift with 1.75 rockers
SN95 Director
Originally Posted by gollum
I would say very close to .265
https://ls1tech.com/forums/showpost....36&postcount=1
