anyone had bad luck with comp 987 dual springs??
ok over christmas I have decided to go with TEA stage II heads along with my new 224*/227* .563"/.569" 114 lsa cam..just wondering if anyone has had any of these springs break? I need good reliability and they sound up to par..but need some reasurance <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> thanks,
carter
carter
Re: anyone had bad luck with comp 987 dual springs??
sweet!don't all TEA stage 2's come with these springs anyways? or is it 947's? lol i dont remember thanks again..anyone else heard of any problems with either 947's or 987's? thanks <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
carter
carter
My TEA 5.3 Stage 2's came with the dual 987 springs.
I've heard of ONE 987 breaking in like FOUR years. The 987 has FAR fewer issues than 941's, 918's or REV-1116's etc.
SRP tested my 987's to make sure they were up to the task of SRP's 224 custom cam with XE-R lobes. All the 987 springs were right on the money. TEA had set the springs up exactly as they should be height wise and all the springs were good.
Never had or heard of a problem with them. Great spring IMO.
I will be taking mine off and haveing them sent to be analyzed here in the next week or so. I will post the results of how the spring rigidity has held up.
MY TEA Stage 1 heads came with the 987 springs. TEA does not mess around and sells proven go-fast stuff for a great price. A solid setup for sure. If you pull the heads, it is a wise investment to have your heads done so a larger diamter spring (1.440") can be installed.
Eric
Eric
ttt
I'm watching this one closely. Broke a 918 and am thinking of switchin to these. It seems that even if you break one these chances are it will break in a way that it does not drop the valve. In that case it is only a nuisance and not such a big deal.
The 5.7L and 4.8/5.3L heads do have to be machined to accept a 1.440" OD dual-spring, such as the 987 (not sure about the 6.0L head, though - maybe someone with some experience with those heads can chime in, but I bet they are the same as the 5.xL heads).
As others have mentioned before in this thread, TEA uses the 987's and does an excellent job with them. My TEA Stage II 5.3L heads were set up with them, and they have been rock-solid so far. I don't think you can go wrong w/ the double-spring as long as you've done your homework and have everything else to complement the setup.
Good luck!
Good luck!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by NoGo:
<strong> Never had or heard of a problem with them. Great spring IMO.
I will be taking mine off and haveing them sent to be analyzed here in the next week or so. I will post the results of how the spring rigidity has held up. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Any update on this? <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Yup.
I didn't get a printout of all the springs like I had asked, but each one of the springs still exhibited the advertised seat pressures within a couple lb's (I don't have the sheet infront of me <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> ).
This is after road racing / drag racing / nitrous abuse on a 226/226 112 .554 cam for over a year.
Good Spring <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" />
