normal for new cam to comsume oil?
let me ask you how you seat them correctly and ill tell you if i did
mother fu@#r
... it does smoke sometimes... not every cold start or any thing... well i know i didnt cram em on.... GD! I did the comp 921 kit with the ti. retainers and the seats and seals were seperate pieces......so all i need to do is to push down on the valve stem seal until it clicks?
You may want to let a couple more people chime in with some other ideas... If you do have to open her back up, might as well atleast look into all the possibilities. My money is on the seals though
i hate our damn plugs.... yeah... the ole TDC method again.... hmm...does this mean my car could have some HP left in her?what else could it be?
As far as some HP left, I wouldnt be too optimistic, unless you had enough oil leaking that it caused carbon deposits on your pistons and your car had some serious knock retard. If thats the case, run some sea foam through the car afterards to clean out the carbon and your timing should come back up.
I also assume youve checked for physical leaks? Particularly where you had to RTV the front cover to the oil pan. You did do that one, right?!?
Good luck man,
-T
Good luck man,
-T
no knock retard either.. well fudge me in the a$$.. looks like ill be under the hood again this weekend (hell and got nuthing better to do)
