IS a cam for me? What cam?
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
LS6 or (Fast intake for cam)
pulley
lid or FIPK
ported TB or the (90mm TB for cam)
gears A4=atleast 3.73, M6=atleast 4.10 or 12 or 9 rear (preferably)*
headers
ory
cat back
Sub frame connectors
Lower control arms
rear sway bar
Torque arm
drag radials
HPtuners
1. Converter-3500 minimum stall. $750-1300 with install.
2. LT headers/y-pipe/cats. 2 grand with install and tune.
3.Cam or cam/heads package. 2 grand for cam package, install and tune.
Prices are approximate. LSI-Edit runs $550 but once you got it, you just need to pay for dyno time.
You will need tuning after headers and cam. Won't hurt after converter either should you have torque management issues.
After all of that I WILL be getting my 11 second timeslips as soon as the weather is good enough to go to the track.
2. LT headers/y-pipe/cats. 2 grand with install and tune. - install them yourself, tune when you get a cam. - 1000
3.Cam or cam/heads package. 2 grand for cam package, install and tune. - install it yourself - 1000
Prices are approximate. LSI-Edit runs $550 but once you got it, you just need to pay for dyno time. - If you mean getting a full lifetime tune somewhere....then prices vary. If you are talking about getting a tuning suite, forget LS1Edit. Go for HPTuners or Flashscan.
a good set of long tubes and that'll cost about 1100... ory about 300... I'd save for the 90tb and 90 intake.. and grab a 12 bolt.. and stall it...
that will suprise you
If I were you: The tb is good for 7hp on a stock car. You should get the torque converter and trani cooler second. Worth every penny. Then do the cam yourself and save money. I did mine in one weekend taking my time using www.ls1howto.com and about $30 worth of tools I had to buy. (Pulley puller and 24 mm socket) Spent $60 on gaskets and stuff and bought the cam used on the for sale section $350 with valvesprings included. I wish you lived around Atlanta 'cause I'd swap your cam for $150.
The headers will run between $399 Pacesetters or $799-$1300 for premium ones.If you don't plan to keep the car forever, Pacesetters will do just fine. I'd do the cam and tb for sure!!! Worth it!
Header install isn't very hard, and swapping throttle bodies is cake.
Coated pacesetters shouldn't let you down, but QTP/Kooks are very good headers.
but lid, stall, headers would be the order I do them... a nice 3200-4000 stall would be the best bang for the buck and make you grin everytime you leave a stoplight
lid is a easy 1-2tenths off your ET and should be about anyone's first mod.
the intake and TB I wouldnt mess with untill you decide on a cam and heads, or when you have done all the other bolt ons. Just my 2 cents anyway
Get a Torque Converter/cooler (Fuddle's is like 410 to your door step)... Whats left get a set of Pacesetter headers/ORY (under 500 I believe). Just those 2 will net you around .6 + of you E.T pretty easily... Just my $.02
