prc dual springs vs comp 921's
I am planning on doing a cam install very soon! I have the lg g5x3 on a 112 lsa and I am wondering what spring kit will work good with this cam. I have heard theat the piston to valve clearance is very minimal and it would be best to invest in a good spring set like the 921's but the 921's are very expensive so i was wondering if any body has the prc springs and are they good or good enough to handle my cam. Also how do they compare to the 921's as far as longevity. Thanks guys any imput would be great
Originally Posted by slt200mph
Got a TSP cam 233 595 112+2 with the PRC dual springs and they work fine got the red line set at 6700 RPM and shifting at 6500 no problems with these springs..
LS1Tech Premium Sponsor
We've sold plenty of sets of the PRC kits to guys running x3 cams The PRC kit has been revised to inlcude a new spring seat, titanium retainers which get you a little more spring pressures & the platinum spring! All for $259.99 off our site
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
That is what I bought from you..very pleased with the purchase..
Originally Posted by jrp
if you want specifics.
Gold
O.D 1.29
135lbs @ 1.800
385lbs open
coil bind @ 1.08
.650 lift
Platinum Spring
OD 1.29
145# @ 1.7850
395# @ ?
921
O.D: 1.300
I.D: .870 (outer spring)
I.D: .655 (inner spring)
135 LBS @ 1.770
400 LBS @ 1.220
COIL BIND @ 1.040
MAX LIFT .650
Gold
O.D 1.29
135lbs @ 1.800
385lbs open
coil bind @ 1.08
.650 lift
Platinum Spring
OD 1.29
145# @ 1.7850
395# @ ?
921
O.D: 1.300
135 LBS @ 1.770
400 LBS @ 1.220
COIL BIND @ 1.040
MAX LIFT .650
If you are concerned about the life span of the PRC platinum springs just call Jason @ TSP and I am sure he will be happy to pass a long all the info on the springs to you..the people at TSP have always been real helpful when ever I called with questions ..I am running their spring kit with the platinum springs and I am very happy with my purchase..that is a lot of quality parts for the $$$..
Thanks for the kind words lst200! I think both spring packages offer you a great product. We've had alot of good luck with the prc spring & they're pretty hard to beat for the price
Jason
Texas Speed
Jason
Texas Speed
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
Jason
Texas Speed
Jason
Texas Speed
Jason..inquiring minds want to know..what kind of longivity can we expect with the platinum springs..?
